[SOLVED] How to update terrain to new format?
The terrain file format has been changed as well, please use the upgrade script: utils/Upgrade/terrain.usc.
So how do I do this?
The online documentation only says this:
Running USC on Windows
To use Interpreter on Windows, follow these steps:
  1. Create a script to be executed and save it with *.usc extension.
  2. Associate usc files with <UnigineSDK>/bin/usc_*.exe. Depending on the postfix, it can be either 32-bit (_86) or 64-bit, debug (d) or release (no postfix) version of the Interpreter.
So could someone please explain me how to use the terrain.usc file
Hi Rob,
Please, check this topic https://developer.unigine.com/forum/topic/2041-solved-problem-with-upgradescript/
In few words:
  1. Copy terrain.usc and usc interpreter tool to the folder with terrain.ter0000, terrain.ter0001 files;
  2. In terminal (command line) execute following commands:
    usc terrain.usc terrain.ter0000
    usc terrain.usc terrain.ter0001
I copied the usc_x64.exe and the terrain.usc files to the folder containing my terrain files (terrain.ter0000 etc)
and when I open command line and type the following and execute it:
usc_x64 terrain.usc TerrainGame.ter0000
Nothing happens not even an error or anything, when I only type usc_x64 it does find the script interpreter
So what am I doing wrong?
  • Copy usc_x64 & terrain.usc to folder with terrain
Open command line
cd path/to/the/terrain/folder/with/terrain
usc_x64.exe terrain.usc TerrainGame.ter0000
It's work for me
  • Open command line
  • cd path/to/the/terrain/folder/with/terrain
  • usc_x64.exe terrain.usc TerrainGame.ter0000
It's work for me
I do this but it doesnt seem to work, now I tried it on the Gameterrain.ter file the one without the numbers behind it and it works but as soon as I try to open the world the editor seems to crash
So the script only works on the GameTerrain.ter file without the numbers but something corrupts and makes it impossible to open my environment
Im lost here...
Hi Rob,
Please, try to use attached *.usc script.
That one does work but I converted all the files but still the terrain wont show ingame, I cant seem to convert the first .ter file without the numbers behind it. All the other ones are converted
Is this why I dont see my terrain?
Rob,
You can use your previos .usc script to upgrade *.ter file. And attached one to upgrade *.ter000x files. This should do the trick.
I just tried this but the older file doesnt seem to work either, could you provide me with an older .usc script that does work on the .ter file?
Hi Rob,
There is short manual how to update your terrain files:
  1. From latest SDK run terrain.usc script via usc-interpreter on your *.ter file:
  2. Copy terrain.usc to terrain_new.usc;
  3. Open terrain_new.usc in text editor and comment lines from 23 to 105 (via /* on line 23 and */ on line 105);
  4. Uncomment lines from 106 to 209 (delete /* 20130508 and * from lines 106 and 107; delete */ on line 209);
  5. Save file;
  6. Run terrain_new.usc script on your *.ter000x files:
    usc_x64 terrain_new.usc TerrainGame.ter0000
    usc_x64 terrain_new.usc TerrainGame.ter0001
  7. Run terrain.usc script on your *.ter000x files again:
    usc_x64 terrain.usc TerrainGame.ter0001
If it is hard to for you to comment and uncomment lines, I've made terrain_new.usc, you can find it in attachement.
terrain_new.zip
