danni.coy Posted May 14, 2013 Share Posted May 14, 2013 This is for an onsite system. After a few hours of operation (varies between say 4 and 20) we get an application crash where non allocated memory is being accessed (c00...005 in windows).We suspect something to do with syncker and the network code since we don't get this crash running in a non networked environment. The log file says nothing and it is windows that is killing off ungine - how do we even begin to debug this? Link to comment
ulf.schroeter Posted May 14, 2013 Share Posted May 14, 2013 If not already done use main_x86/64.exe for running the application as this might give some additional error/debug information e.g. stack overflow/invalid array index etc. for tracking down the actual cause of the crash. Even better idea might be to run this version from within debugger so you can intercept the exception for getting a hint on error 'location' by inspecting the call stack. Link to comment
ulf.schroeter Posted May 14, 2013 Share Posted May 14, 2013 Yes, of course the debug build with the - in my post missing - little additional 'd' Link to comment
binstream Posted May 14, 2013 Share Posted May 14, 2013 You can also take a look at these recommendations: https://developer.unigine.com/forum/topic/1409-how-to-submit-a-good-bug-report/ Link to comment
ulf.schroeter Posted May 14, 2013 Share Posted May 14, 2013 BTW as you are expecting the problem within network/syncher code section: it might be worth to try to somehow dramatically increase the network communication frequency ("time-lapse") of your application, so you don't have to wait a whole day for the problem to show up, but just some minutes or hours. Link to comment
danni.coy Posted May 17, 2013 Author Share Posted May 17, 2013 Thanks ulf... I will think about that, we are doing a pretty good job of saturating the network as it is. The d version isn't giving any hints and the application is being killed from the windows side. Thanks binstream. I will see about getting my hands on a copy of Visual Studio... Link to comment
steve3d Posted May 20, 2013 Share Posted May 20, 2013 I've got one of this kind of problem, and I successfully solved this problem, it's a problem of small class in your script. Try to comment each class of your script to narrow down the problem. and I don't think the debug version of engine will do any help on this. I've created a date class in script. and got exact same error like yours, so double check your class in script. Link to comment
