mathias.poupard Posted May 6, 2013 Share Posted May 6, 2013 EDIT: the first issue reported was due to an obscure conversion that took place in our own codebase I was not aware about. Unigine's 2D message screen positioning works as expected. Sorry about the inconvenience. Link to comment
mathias.poupard Posted May 10, 2013 Author Share Posted May 10, 2013 EDIT: post edited to remove references to the previous post which was not a Unigine bug. Hello again, :) We have just switched to the latest Unigine version and the signature of the renderMessage2D function has changed and now asks for an additional 3D vector parameter named "center" which, as I understand it, would be the origin of the local coordinate system of the text quad. The way the X and Y components of the "center" vector are treated seems inconsistent. Hereafter are a few screenshots to illustrate the issue: (Shouldn't it be the result for (1,-1,0) ?) (Shouldn't it be the result for (-1,1,0) ?) Here is the local coordinate system I would expect to be consistent with the way we position the text message into the coordinate system of the viewport (or maybe with (0,0) at the bottom-left corner and (1,1) at the top-right one ?): Thanks for reading. Link to comment
frustum Posted May 10, 2013 Share Posted May 10, 2013 Vertical axis will be flipped in the next SDK. Thanks. Link to comment
mathias.poupard Posted May 15, 2013 Author Share Posted May 15, 2013 Hello, just a quick related question : I used the renderQuad2D() function for the first time today and it uses yet another coordinate system for positioning in screen/image space : from top-left corner (0,0) to bottom-right (1,1) (same for renderPoint2D() and renderTriangle2D()). Will all those positioning systems (that is, 2D primitive in screen space, 2D message in screen space and 2D message anchor in local space ("center" parameter)) be unified in the next SDK? Link to comment
frustum Posted May 30, 2013 Share Posted May 30, 2013 visualizer coordinate system will be the same. top-left corner is 0,0; bottom-right corner is 1,1. Link to comment
