maimonides Posted April 16, 2013 Share Posted April 16, 2013 I am going thru Schemer and i don't see how to make schemer interact with variable in the normal world script and also how to possibly supply parameters to the schemer script. Usecase: Let's say i want to use schemer script to be run, when use clicks on some node. Schemer script would trigger rotating some other node around axis z. How would i input the id of node to access and how would i access node position etc from inside the schemer script? As in have a "lever" and want to use parametrized schemer script to open door and pull the lever, just by moving and rotating around relevant nodes. Tutorial in documentation is solipsistic. Some practical examples moving variable objects around in the scene would be much more useful. Link to comment
maimonides Posted April 16, 2013 Author Share Posted April 16, 2013 Figured it out eventually. Though example i asked for above would make things easier i think. Link to comment
