mohsen.nikroo Posted March 28, 2013 Share Posted March 28, 2013 HiI need a shot in the direction of my mouseThis program performs the following I used to get the cursor GetDir() function AngleI get the following command to launch helpdir00 = vec3 (cos (Angle_x * Deg2Rad), sin (Angle_x * Deg2Rad), sin (Angle_y * Deg2Rad)); The center screen works but the problem is there are fourAfter firing, the cursor goes away.Please help me here.Thanks Moshak.rar Link to comment
manguste Posted April 1, 2013 Share Posted April 1, 2013 As I get get it, you use a multi-monitor configuration. But how it is launched exactly? And what do you mean by "After firing, the cursor goes away"? Link to comment
necris Posted April 3, 2013 Share Posted April 3, 2013 Mohsen, To help us reproduce and fix the issue, please describe it in details: What you expected or needed to happen What you did step-by-step (please, use a numbered list!) What happened Link to comment
mohsen.nikroo Posted April 4, 2013 Author Share Posted April 4, 2013 Thanks for your answerI have a project that I'll understand if you can run.My goal is that when an object (ball) was created directly by double-clicking the mouse to move the cursorAnd does not distance the mouse cursor in the center of the right answersBut the four sides of the screen do not give correct outputWhen adding cameras(call addcamera in updatefunction ) to solve the problem to some extent, but there is still a problem Link to comment
necris Posted April 15, 2013 Share Posted April 15, 2013 Mohsen, Sorry for late response. What do you mean by And does not distance the mouse cursor in the center of the right answersBut the four sides of the screen do not give correct output As I get get it, your issue is about stretching the ball near the screen edges? Please, explain your issue in detail. Link to comment
