fabrice.picou Posted March 20, 2013 Share Posted March 20, 2013 Hi, I must do a building with reflection at each level. I applied a mesh_reflection_2D_base and I've got no reflection. Must each surface have a different material ? Must each surface be a separated mesh ? Thanks ! test.rar Link to comment
nat.harrold Posted March 20, 2013 Share Posted March 20, 2013 Hi Fabrice, you would expect no reflection with your current set up. Each surface must be separate for each plane of reflection AND each of these surfaces must have their pivot in the centre. (Export from pivot not world) The additional plane you have in there has its pivot well below the surface and off to the side (which seems you exported from world and not pivot) you can make one plane, move it into position then copy it in this case you can also share the same material (but it does look weird with "no shadows in reflection" bug) Link to comment
fabrice.picou Posted March 21, 2013 Author Share Posted March 21, 2013 Thank you for your reply Nat ! Link to comment
