[SOLVED] when clicking on screen cursor is hiding
Character control for RPG style, Got one problem - when clicking on screen cursor is hiding, when pressing esc its showing. Must control that but can't find part of code that is responsible for that. Any ideas or help please?
Link to post
core/scripts/system.h file has several defines for different mouse models:
SOFT_MOUSE is demo mouse mode.
USER_MOUSE the mouse is not controlled by system script.
Link to post
  • 1 month later...
I have similary problem... I get system.h, but in Unigine 2010-11-29 this lines commented:
//#define USER_MOUSE
//#define SOFT_MOUSE
//#define EXPORT_LOCALE
//#define EXPORT_EXTERN
I try use engine.app.getMouseShow()/engine.app.setMouseShow() but this is not help...
I need sweech this two regimes: in one user control game's character and cursor is hided, but when user get some game's window - his character lost control and cursor is show, then user can move cursor to manipulate with window... how it could be done? Thanks.
Link to post
Try setMouseGrab.
Link to post
Define USER_MOUSE or SOFT_MOUSE inside your custom unigine.cpp file before system.h include.
#define USER_MOUSE
#include <core/unigine.h>
#include <core/scripts/system.h>
Link to post
If I understand right, custom unigine.cpp - it's my main.cpp, my "enter point" in application?
I added this define in it:
#define USER_MOUSE
#include <source/scripts/game/Game.h>
#include <source/scripts/editor/Editor.h>
#include <source/scripts/Global.h>
int init()
Source::initGlobal();
But it's working exectly like earlier...
When I use #define USER_MOUSE unigine not manage cursor and my application can show/hide it through engine.app.setMouseShow() or not?
Link to post
I don't use my custom unigine.cpp (I have not necessity yet), so I try add this define to SDK-binary\data\core\unigine.cpp - it's also don't get necessary result
Link to post
It's OK to use custom unigine.cpp in the project, take a look at our samples (Heaven and so on).
Refer to the manual for more info: Tutorials -> Adding Scripts to the Project
Link to post
Ok, I try to use custom unigine.cpp:
I update my exec64.bat file:
main_x64d
-system_script data/source/unigine.cpp
-console_command "world_load source/main"
My project placed in folder SDK-binary\data\source\ (main.cpp and main.world placed here)
unigine.cpp looks like:
/* Copyright (C) 2005-2010, Unigine Corp. All rights reserved.
* File:    unigine.cpp
* Desc:    Unigine system
* Version: 1.00
* Author:  Ivan Gulaev <tmifx@unigine.com>
* This file is part of the Unigine engine (http://unigine.com/).
* Your use and or redistribution of this software in source and / or
* binary form, with or without modification, is subject to: (i) your
* ongoing acceptance of and compliance with the terms and conditions of
* the Unigine License Agreement; and (ii) your inclusion of this notice
* in any version of this software that you use or redistribute.
* A copy of the Unigine License Agreement is available by contacting
* Unigine Corp. at http://unigine.com/
#include <unigine.h>
#include <system.h>
* init/shutdown
int init() {
systemInit();
engine.console.run("world_load source/main");
log.message("custom unigine.cpp init()\n");
int shutdown() {
systemShutdown();
* update
int update() {
systemUpdate();
But when I execure my bat file and launch unigine my custom file unigine.cpp not execute, log message custom unigine.cpp init() not output, and in console have no errors or warnings about custom unigine.cpp not finded or something else.
Link to post
In Windows console file all the same output Loading "core/unigine.cpp" 69ms
What is your data path? Please attach the full log.html
Link to post
Unigine log file
13:17:11 Loading "E:/unigine/SDK-binary/bin/unigine.cfg"...
13:17:15 Loading "opengl32.dll"...
13:17:15 Set 960x540 windowed video mode
13:17:17 Set 1.00 gamma value
13:17:17 Unigine engine http://unigine.com/
13:17:17 Binary: Windows 64bit Visual C++ 1600 Debug Nov 29 2010
13:17:17 App path: E:/unigine/SDK-binary/bin/
13:17:17 Data path: E:/unigine/SDK-binary/data/
13:17:17 Save path: E:/unigine/SDK-binary/bin/
13:17:17
13:17:17 ---- System ----
13:17:17 System: Windows 7 (build 7600) 64bit
13:17:17 CPU: Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz 1994MHz MMX SSE SSE2 SSE3 SSSE3 HTT
13:17:17 GPU: NVIDIA GeForce 9300M GS 8.17.12.6099
13:17:17 System memory: 2042 Mb
13:17:17 Video memory: 256 Mb
13:17:17
13:17:17 ---- MathLib ----
13:17:17 Set SSE simd processor
13:17:17
13:17:18 ---- Sound ----
13:17:18 NULL
13:17:18
13:17:18 ---- Render ----
13:17:18 Renderer: NVIDIA NV50 256Mb
13:17:18 OpenGL vendor: NVIDIA Corporation
13:17:18 OpenGL renderer: GeForce 9300M GS/PCI/SSE2
13:17:18 OpenGL version: 3.3.0
13:17:18 Found required GL_ARB_map_buffer_range
13:17:18 Found required GL_ARB_vertex_array_object
13:17:18 Found required GL_ARB_vertex_buffer_object
13:17:18 Found required GL_ARB_half_float_vertex
13:17:18 Found required GL_ARB_half_float_pixel
13:17:18 Found required GL_ARB_occlusion_query
13:17:18 Found required GL_EXT_texture3D
13:17:18 Found required GL_EXT_texture_cube_map
13:17:18 Found required GL_EXT_texture_sRGB
13:17:18 Found required GL_EXT_texture_swizzle
13:17:18 Found required GL_ARB_shader_object
13:17:18 Found required GL_ARB_vertex_shader
13:17:18 Found required GL_ARB_fragment_shader
13:17:18 Found required GL_ARB_draw_buffers
13:17:18 Found required GL_ARB_framebuffer_object
13:17:18 Found required GL_EXT_framebuffer_blit
13:17:18 Found required GL_EXT_framebuffer_multisample
13:17:18 Found optional GL_ARB_draw_instanced
13:17:18 Found optional GL_ARB_transform_feedback
13:17:18 Found optional GL_ARB_draw_elements_base_vertex
13:17:18 Found optional GL_EXT_draw_buffers2
13:17:18 Found optional GL_ARB_blend_func_extended
13:17:18 Found optional GL_ARB_uniform_buffer_object
13:17:18 Found optional GL_ARB_geometry_shader4
13:17:18 Found optional GL_ARB_gpu_shader4
13:17:18 Found optional GL_EXT_Cg_shader
13:17:18 Found optional GL_ARB_texture_rg
13:17:18 Found optional GL_ARB_texture_array
13:17:18 Found optional GL_ARB_texture_snorm
13:17:18 Found optional GL_ARB_texture_multisample
13:17:18 Found optional GL_ARB_texture_compression
13:17:18 Found optional GL_ARB_texture_compression_rgtc
13:17:18 Found optional GL_ARB_seamless_cube_map
13:17:18 Found optional RGB10A2 render texture format
13:17:18 Shading language: 3.30 NVIDIA via Cg compiler
13:17:18 Maximum texture size: 8192
13:17:18 Maximum texture units: 32
13:17:18 Maximum draw buffers: 8
13:17:18
13:17:18 ---- Physics ----
13:17:18 Physics: Multi-threaded
13:17:18
13:17:18 Unigine~# world_load source/main
13:17:23 ---- Interpreter ----
13:17:23 Version: 2.38
13:17:23
13:17:24 Loading "core/unigine.cpp" 889ms
13:17:24 Loading "core/locale/unigine.en" dictionary
13:17:24 Loading "core/materials/unigine_post.mat" 11 materials 11 shaders 47ms
13:17:24 Loading "core/materials/unigine_render.mat" 38 materials 178 shaders 11ms
13:17:24 Loading "core/materials/unigine_meshes.mat" 17 materials 11532 shaders 199ms
13:17:24 Loading "core/materials/unigine_terrains.mat" 1 material 144 shaders 1ms
13:17:24 Loading "core/materials/unigine_grass.mat" 1 material 69 shaders 3ms
13:17:24 Loading "core/materials/unigine_particles.mat" 1 material 45 shaders 4ms
13:17:24 Loading "core/materials/unigine_billboards.mat" 1 material 69 shaders 4ms
13:17:24 Loading "core/materials/unigine_volumes.mat" 6 materials 45 shaders 8ms
13:17:24 Loading "core/materials/unigine_guis.mat" 1 material 70 shaders 2ms
13:17:25 Loading "core/materials/unigine_water.mat" 1 material 101 shaders 50ms
13:17:25 Loading "core/materials/unigine_skies.mat" 1 material 13 shaders 41ms
13:17:25 Loading "core/materials/unigine_decals.mat" 1 material 55 shaders 3ms
13:17:25 Loading "core/properties/unigine.prop" 2 properties 0ms
13:17:25 Unigine~# editor_load
13:17:25 editor.showKeyLine();
13:17:25 source/scripts/editor/gui/ToolBar.h:78: Interpreter::parse(): unknown token "editor"
13:17:28 Loading "data/core/editor/editor.cpp" 2165ms
13:17:28
13:17:28 ---- Editor ----
13:17:28 Version: 0.54
13:17:28
13:17:50 Unigine~# world_load source/main
13:17:50 NameSpace::check(): unused variable "Source::ToolBar::aaaa"
13:17:50 NameSpace::check(): unused variable "Source::ToolBar::reloadWidgetIcon"
13:17:50 NameSpace::check(): unused variable "Source::ToolBar::changeCameraIcon"
13:17:50 NameSpace::check(): unused variable "Source::Editor::gui"
13:17:50 NameSpace::check(): unused variable "Source::NoteList::gui"
13:17:50 NameSpace::check(): unused variable "Source::Cursor::gui"
13:17:50 NameSpace::check(): unused variable "Source::Inventory::reloadWidgetIcon"
13:17:50 NameSpace::check(): unused variable "Source::Inventory::changeCameraIcon"
13:17:50 NameSpace::check(): unused variable "Source::TextPanel::spriteTop"
13:17:50 NameSpace::check(): unused variable "Source::TextPanel::spriteMiddle"
13:17:50 NameSpace::check(): unused variable "Source::TextPanel::spriteBottom"
13:17:50 NameSpace::check(): unused variable "Source::TextPanel::prevPageButton"
13:17:50 NameSpace::check(): unused variable "Source::TextPanel::nextPageButton"
13:17:50 NameSpace::check(): unused variable "Source::BaseObject::REDABILITY_OBJECT"
13:17:50 NameSpace::check(): unused variable "Source::BaseObject::HAND_OBJECT"
13:17:50 NameSpace::check(): unused variable "Source::BaseObject::INVENTORY_OBJECT"
13:17:50 NameSpace::check(): unused variable "Source::BaseObject::HIERARCHICAL_OBJECT"
13:17:50 NameSpace::check(): unused variable "Source::BaseObject::MODIFICATING_OBJECT"
13:17:50 NameSpace::check(): unused variable "Source::BaseObject::INTERACTIVE_OBJECT"
13:17:50 NameSpace::check(): unused variable "Source::GameObject::active"
13:17:50 NameSpace::check(): unused variable "Source::GameObject::orientation"
13:17:50 NameSpace::check(): unused variable "Source::Revolvable::rotation"
13:17:50 NameSpace::check(): unused variable "Source::Revolvable::rotToMouseSpeed"
13:17:50 NameSpace::check(): unused variable "Source::CharacterBase::aaa"
13:17:50 NameSpace::check(): unused variable "Source::Character::angleTest"
13:17:50 NameSpace::check(): unused variable "Source::Character::increase"
13:17:50 NameSpace::check(): unused array "Source::Game::boxes"
13:17:50 NameSpace::check(): unused variable "target_height" in "Source::CharacterBase::update" function
13:17:50 NameSpace::check(): unused variable "text" in "Source::Game::initGUI" function
13:17:50 NameSpace::check(): unused variable "friction" in "Source::Game::bodyContact" function
13:17:50 NameSpace::check(): unused variable "velocity" in "Source::Game::bodyContact" function
13:17:50 NameSpace::check(): unused variable "time" in "Source::Revolvable::update" function
13:17:50 NameSpace::check(): unused variable "indexBoneHip" in "Source::Revolvable::update" function
13:17:50 NameSpace::check(): unused variable "indexBoneHead" in "Source::Revolvable::update" function
13:17:50 NameSpace::check(): unused variable "radius" in "Source::Game::updateInteraction" function
13:17:50 NameSpace::check(): unused variable "desc" in "Source::Game::updateMouseState" function
13:17:50 NameSpace::check(): unused variable "rotation" in "Source::Game::updateMouseState" function
13:17:50 Loading "source/main.cpp" 515ms
13:17:50 Loading "source/materials/source.mat" 6 materials 28ms
13:17:50 Loading "source/properties/objects.prop" 7 properties 21ms
13:17:51 Loading "source/main.world" 393ms
13:17:51
13:17:51 ---- Editor Source ----
13:17:51 Version: 0.1
13:17:51
13:17:55 Unigine~# editor_quit
13:17:55
13:17:55 ---- Game Source ----
13:17:55 Version: 0.1
13:17:55
13:17:56 engine.app.getWidth(): 960
13:17:56 vBox.getWidth(): 544
13:17:56 x: 412
13:17:56 game: aaaaaaaaaaaaaaaa
13:17:56 ui: UserInterface 000000000AF53060 external (9:5:5)
13:17:56 mainPanel: WidgetVBox 000000000384EC80 external (11:2:2)
13:17:56 source = SoundSource 0000000003D5C8E0 external (70:0:0)
13:17:56 Game::init()
13:17:56 source = location
13:17:56 source = cube
13:17:56 prop.getName(): HandObject
13:17:56 source = table
13:17:56 prop.getName(): ReadabilityObject
13:17:56 source = robot
13:17:56 source = robotCharacter
13:17:56 prop.getName(): InteractiveObject
13:17:56 character: Source::Character 000000000482D5F0 (2621455:0:0)
13:17:56 robotSkin: ObjectMeshSkinned 0000000003D468B0 external (85:0:0)
13:17:56 Editor::shutdown()
13:17:56 Editor::destructor()
13:17:57 enterCallback: 1
13:17:58 ToolBar::buttonPressHandler(): 1
13:17:59 GameGlobal::eventKeyRelease(): 100
13:17:59 enterCallback: 1
13:17:59 GameGlobal::eventKeyRelease(): 119
13:18:03 GameGlobal::eventKeyRelease(): 256
I try to use in bat file both -system_script data/source/unigine.cpp and -system_script source/unigine.cpp paths
I could attach all test project, if it be easier
Link to post
send .bat launcher and customized unigine.cpp
Link to post
Oh, I set each parameter in .bat file from new line... and they was ignored (
Now I use next .bat file:
main_x64d -system_script source/unigine.cpp
This is work: custom unigine.cpp file is loading and system cursor always showed, thanks. But I need a little another functionality ;) Sorry, I think this post about how show/hide unigine cursor, not a system (in my case Windows) cursor... I need manage custom unigine cursor, is it possible? Thanks.
Link to post
What exactly do you need to achieve?
<Mind-reading>
See engine.app.setMouseGrab() function.
</Mind-reading>
Link to post
I see example TmifXgameTD and use next check:
if (engine.app.getMouseButton() && !engine.controls.isMouseEnabled())
engine.controls.setMouseEnabled(1);
This code is enough - I can use it when user interact with menus, and omit it when user control his PlayerActor. I only couldn't understand, what do function engine.app.getMouseButton() in this pattern. Thanks.
Link to post
Some experiments show, that this code not much too :)
I use #define USER_MOUSE (how you recommended) and describe my cursor behavior based on code from update() function from system.h. It works, thanks a lot :)
Link to post
Sorry forgot to respond we also sorted this, thanks for all the extra info.
Link to post
