demostenes Posted March 19, 2013 Share Posted March 19, 2013 What is supposed usage of noice feature for grabbing billboards? Noise in alfa channel is causing "atefacts" around billboards, so I dont know in which situation this can be good....Well, it can help with visual quality of trees like conifers, but artefacts around billboars are making it not much usable. I know that tuning of parametr alfa in material can help I bit, but...So I am interested, what exactly was this feature meant for. Btw, billboards for trees are always square, which is imho performance wasting (cca 3x bigger area than really neded, tree is in most cases rectangular), would be possible to optimize this? Link to comment
demostenes Posted March 20, 2013 Author Share Posted March 20, 2013 Btw, billboards for trees are always square, which is imho performance wasting (cca 3x bigger area than really neded, tree is in most cases rectangular), would be possible to optimize this? Never mind, I ve discovered aspect parametr ;) Link to comment
manguste Posted April 1, 2013 Share Posted April 1, 2013 Noise option is for smoother switching between two impostors. Let's say, when a front-looking impostor (from a texture) need to be changed for a side-looking one, the engine uses baked noise to render the transition. You can it see on the picture, one impostor is gradually changed for another as the camera turns around it. Link to comment
demostenes Posted April 1, 2013 Author Share Posted April 1, 2013 Noise option is for smoother switching between two impostors. Let's say, when a front-looking impostor (from a texture) need to be changed for a side-looking one, the engine uses baked noise to render the transition. You can it see on the picture, one impostor is gradually changed for another as the camera turns around it. Thanks for explanation! Link to comment
