ulf.schroeter Posted March 12, 2013 Share Posted March 12, 2013 problem Splitting some fixed-column-number, comma-separated-value (CSV) string is a common task. Unfortunately current implementation of strsplit() will drop empty tokens and will only return a subset of columns e.g. strsplit( "col1;col2;;;col5", ";", tokens) -> "col1", "col2", "col5" Empty columns 3+4 will therefore be "dropped". This renders strsplit() more or less useless for the most common task of CSV parsing were empty columns should be kept in the output e.g. "col1", "col2", "", "", "col5" so column sequence/association of the output remains intact. proposal Addition of an optional flag argument e.g. keepEmpty to suppress current removal of empty columns in output. By using a default argument of "0" it should be possible to keep the modification compatible with current script code. Link to comment
manguste Posted March 14, 2013 Share Posted March 14, 2013 Ulf, Got you, but Frustum needs to check what was the reason to implement it this way in the first place. As soon as this issues is cleared, we'll write you back. may take some time, however. Will keep you posted. Link to comment
ulf.schroeter Posted March 14, 2013 Author Share Posted March 14, 2013 Yep, temporary work-around /** * Split CVS string separated by specified character into tokens. * * REMARK we cannot use UNIGINE strplit as this function will drop empty columns * * @param row data row string * @param delimiter token delimiter character * @param tokens splitted string tokens * * @return token count */ int split( string row, string delimiters, string tokens[] ) { string data = row; tokens.clear(); while( 1 ) { // find next left-most delimiter character int splitPos = -1; for( int i=0; i<strlen(delimiters); i++ ) { int pos = strstr( data, substr( delimiters, i, i+1 ) ); if( pos != -1 ) { if( splitPos != -1 ) splitPos = min( pos, splitPos ); else splitPos = pos; } } if( splitPos == -1 ) break; // no more delimiter characters // extract next token tokens.append( trim( substr( data, 0, splitPos ) ) ); // remaining row string data = substr( data, splitPos + 1, strlen(data) - ( splitPos + 1 ) ); } tokens.append( trim( data ) ); return tokens.size(); } Link to comment
manguste Posted March 15, 2013 Share Posted March 15, 2013 Thx for sharing that until we clear it out. Link to comment
