[SOLVED] why fire LeaveCallback when re-add physics for object Model
 I have added PhysicalTrigger  through scrpit like below:
trigger = add_editor( new PhysicalTrigger( Shape_BOX, position ) );
trigger.setEnterCallback("enterCallBack");
trigger.setLeaveCallback("leaveCallBack");
  void enterCallback(Body body)
        Object object = body.getObject();
        object.setMaterialState("ambient",2,0);
  void leaveCallback(Body body)
        object.setMaterialState("ambient",1,0);
after that ,i added physics for each object through scrpit.when the trigger enter or leave some object,it could be detected.
then,i remove these physics through sripts like below and re-added physics when the trigger was inside one of the objects:
foreach(Node node; nodes)
  if (node.getType()==NODE_OBJECT_MESH)
      Object obj=node_cast(node);
      Body body=obj.getBody();
      obj.setBody(NULL);
      Shape shape=body.getShape(0);//only add one physics
      body.removeShape(shape);
      delete class_append(shape);
      delete class_append(body);
after "re-added physics" operation,system fire leaveCallback but the parameter of "body" was invalid and caused the application to crash.
did i remove physics incorrect?
thanks.
hi ,maguste,
as you mentioned,deleting shapes is redundant.
As far as my understanding, when the physics trigger enters the object, an enterCallback will be triggered. If at this time I delete this body and re-add another body into the object, it will fire a leaveCallback when updateContacts() calls. However, the problem is the previous body from the entercallback to the leavecallback has already been deleted and therefore it leads to a crash.
So instead what I did is something like this and the app run well:
1.clear bodies
2.set trigger callbacks to NULL
3.updateContacts
4.reset trigger callbacks to previous calls.
thank you .
If you got it right, that's great. For any future cases, please provide a minimal test scene for reproduction. This way we can check it if it's a bug on our side or (since it's minimal) you go against UnigineScript syntax or logic. Or you can get what's wrong right while creating if :)
