pramod.s Posted January 18, 2013 Share Posted January 18, 2013 Is there any way to run a .bat file using unigine script? I have an OpenGl simulator and now want to start that using unigine button. Also how to check the status of cmd(written in .bat) i.e whether it is executed or not. Thanks in advance. Link to comment
frustum Posted January 18, 2013 Share Posted January 18, 2013 Check the system() script function. Link to comment
pramod.s Posted January 21, 2013 Author Share Posted January 21, 2013 which system script function need to be called. I checked the document but didnt get any function or way to call windows command using world script or system script. some more pointers please. Link to comment
frustum Posted January 21, 2013 Share Posted January 21, 2013 system(format("fxc.exe /nologo /O3 /Zpc /Ges /Tvs_5_0 /Emain /Fo%s %s",dest,src)); Link to comment
pramod.s Posted January 21, 2013 Author Share Posted January 21, 2013 Thanks that worked :) 1 Link to comment
pramod.s Posted January 24, 2013 Author Share Posted January 24, 2013 Now I want to run more than one command, but as I run the 1st one the unigine holds the resource and my 2nd command dosent execute. Also if I try to use "start" command its not behaving as expected.(i.e its not opening a new window) system("start cmd /K \"cd /d c:/somefolder\""); Link to comment
frustum Posted January 25, 2013 Share Posted January 25, 2013 system("cmd.exe /c start cmd.exe /K \"cd /d c:/somefolder\""); Link to comment
