craig.biggs_ Posted December 17, 2012 Share Posted December 17, 2012 I've identified a bug in your editor code as a result of attempting to save a node. This exists in the Nov 2012 SDK for double precision builds and is easily reproducable. 1) Load a world 2) Select a node in the editor 3) Click on "Export selected node with all children into the file" button and choose a file and select OK At this point, the node is not saved and a dvec3 to vec3 conversion error occurs. On closer inspection line 1841 and 1842 of editor_nodes.h incorrectly use "vec3" instead of "Vec3" in the function Nodes::save_clicked() vec3 local_position = node.getPosition(); node.setPosition(vec3_zero); By modifying that type in these lines of code, the problem is rectified. Link to comment
necris Posted December 17, 2012 Share Posted December 17, 2012 Thanks, we've reproduced this issue and passed it to developers. Link to comment
ulf.schroeter Posted December 17, 2012 Share Posted December 17, 2012 This is 3-4 bug report on "vec3 should be Vec3 for double precision builds" issue. Wouldn't it make sense to solve this pitfall once and finally by a complete code review of editor code (assuming a simple text replace of vec3 by Vec3 would be too brute-force) ? Link to comment
manguste Posted December 17, 2012 Share Posted December 17, 2012 Ulf, we do hope that was the last issue. Link to comment
ulf.schroeter Posted December 17, 2012 Share Posted December 17, 2012 Ulf, we do hope that was the last issue. hahah, yes, hope always dies last ^_^ Link to comment
