[SOLVED] Problem with ObjectGui mouse control
Problem
Strange system behavior when an objectgui widget is clicked. It causes wrong intersection operations and player control failure.
Reproduction steps
It's not automatic but easy to reproduce (just repeat steps 3-4 until it happens):
  1. Place attached zip content in data/samples folder.
  2. Execute guiproblem world
  3. Click on any of the labels (an engine message is shown "s:label 1" or "s:label 2")
  4. Click over the box and the label callback is invoked again. Once this happens, you can click the background and the callback will be invoked again. In addition you wouldn't be able to control player.
Thanks in advance.
teacherview.zip
Thank you for this issue, we'll fix that!
The problem is that your label bounds are beyond ObjectGUI, so as a workaround try to keep your widgets bounds inside or resize screen on your ObjectGUI. In sample you can remove first digit from labels and see the results.
Tip: for debugging purposes it's good to enable background on your ObjectGUI node. This can be done by calling your_object_gui_instance.setBackground(1);
  • 9 months later...
