carl.sutton Posted October 17, 2012 Share Posted October 17, 2012 Hello, Using the following code (called once per update) I am creating a set of images to stitch together into a movie using an external program. The problem is, I am getting random light flickering between images that makes the end result unusable. ALL lights in scene are dynamic lights (i.e. spot, proj, omni, world lights). My first thought was that I had HDR on, but it is disabled both in the scene and in the renderImage2D function. I also have an extremely low framerate during this rendering period as I have everything on maximum for the best movie output (although I wouldn't have thought a low framerate would make a difference). Any idea why these images are rendering with flickering light effects and/or any possible solutions? Image image = new Image(); engine.render.renderImage2D(player.getProjection(), player.getModelview(), image, resolutionX, resolutionY, "", RENDER_HDR_DISABLED); string saveFile = format("%s/img%s.png", filePath, GetFrameString()); image.save(saveFile); delete image; Thanks. Link to comment
carl.sutton Posted October 18, 2012 Author Share Posted October 18, 2012 https://dl.dropbox.com/u/102501555/ShopDemo.mp4 here is an example of the result I'm getting (apologies for the biggish 50mb file size, but this one shows the flicker bug really clearly) Link to comment
ulf.schroeter Posted October 18, 2012 Share Posted October 18, 2012 Do you use glow post-processing effect ? The lights under the roof show quite some variations Link to comment
carl.sutton Posted October 19, 2012 Author Share Posted October 19, 2012 I have an interesting update! I tried disabling the glow post process as you suggested Ulf, but to no avail. I then went through destroying and picking away at the project piece by piece. The weird result is that having a LightWorld object in my scene is the cause of the flicker, but when disabling the scattering pass, it continued to cause the problem. Only by having all LightWorld objects disabled (which in my case was just the 1) did the flicker stop occuring between animation frames. Can it be explained why the LightWorld object is doing this? Perhaps there is a bug here? Link to comment
manguste Posted October 22, 2012 Share Posted October 22, 2012 Can you send us a sample test scene? Because we haven't had such problems when capturing video. If it's not HDR, it's hard to say what the problem is without testing. Link to comment
carl.sutton Posted October 23, 2012 Author Share Posted October 23, 2012 Apologies, I have misinformed you. Seems I disabled the LightWorld's root node which also contained an ObjectSky. The flickering is caused by the shadows of the clouds! These are being updated in realtime compared to the really slow render time I'm producing my images in so the shadow changes the clouds cause look really dramatic. I think I'm going to take the easy way out and just drop the clouds completely as they are not really necessary in our project. Thank you for your time guys. Link to comment
