[SOLVED] Have some problem to set Textures in earth Model
Hello, dear everyone, I have new problem
I have create a earth model with 3 LOD levels
the LOD level 0 with 2 tiles, a tile is actually a dynamic mesh.
the LOD level 1 with 8 tiles
the LOD level 2 with 32 tiles.
I set each tile a different diffuse texture image with the following code:
take LOD level 1 as an example(some pseduo code)
// start with a circulation to create each tile
ObjectMeshDynamic *pLod1[8];
// 8 image object with image data
Image image[8];
for (int i = 0; i < 7; i++)
ObjectMeshDynamic *pTile = new ObjectMeshDynamic;
pLod1 = pTile;
// some add vertex, normal, index and texture coordinate code, omitted
// set material for the tile
pTile->setMaterial("mesh_base", "*");
pTile->setProperty("surface_base","*");
// get the material of the tile and set a diffuse texture image
Material* mat = pTile->getMaterial(0);
Texture* texture = mat->getImageTexture(0);
texture->setImage(image);
when rendered , all 8 tile only show the last texture image and seems all 8 tile share a same material.
So what is the right method to set each tile a independent material when changing its parameters does not affect other tiles?
please help!
LOD 0
LOD 1
LOD 2
Thanks ulf,
int setImageTextureImage(int id,Image image,int dynamic) ;
i did not see such a interface with three paremeters in my project, is it deprecated? I only see
a interface with two paremeters.
int setImageTextureImage(int num,const Image ℑ);
Then how to create an individual material instances ? can show me some example code for reference
It's brand new, see this post for background.
Have a look into the numerous UNIGINE code examples e.g. for Objects and documentation for engine.materials .cloneMaterial(). Maybe it's even simpler with Object::getMaterialInherit()
You are lucky, found some snippet
  // created inherited materials
  engine.materials.inheritMaterial( "mesh_base", "bug/bug.mat", "red_white" );
  engine.materials.inheritMaterial( "mesh_base", "bug/bug.mat", "green_white");
// object for red-white diffuse texture update
  object_red_white = add_editor(Unigine::createBox(vec3(10.0f)));
  object_red_white.setWorldTransform(translate(Vec3(0.0f,-15.0f,10.0f)));
  object_red_white.setMaterial("red_white", "*");
  object_red_white.setProperty("surface_base","*");
  updateImage( image, RED_WHITE );
  material = object_red_white.getMaterialInherit(0);
  material.setImageTextureImage( material.findTexture("diffuse"), imageA, 1);
  // object for green-white diffuse texture update
 object_green_white = add_editor(Unigine::createBox(vec3(10.0f)));
 object_green_white.setWorldTransform(translate(Vec3(0.0f,0.0f,10.0f)));
 object_green_white.setMaterial("green_white","*");
 object_green_white.setProperty("surface_base","*");
 material = object_green_white.getMaterialInherit(0);
 material.setImageTextureImage( material.findTexture("diffuse"), imageB, 1);
Indeed he is :)
Chao, you need to update to the latest SDK if you still have not done that.
