HarpSeal1 Posted October 11, 2012 Share Posted October 11, 2012 I have created a user class called Entity to extend the functionality of ObjectMesh. It works fine but I want use a Node file that defines physics bodies/joints and materials for the ObjectMesh. I'll try to do something like this: Entity ent = new Entity(fileName); Node node = engine.world.getNode(ent.getID()); Entity castedEnt = Entity::cast(node); castedEnt.test(); class Entity : ObjectMesh { Entity(string filename) { ObjectMesh m = node_load(filename); extern = m; } void test() { log.message("works\n"); } }; When I call castedEnt.test() Machine::do_callucf(): "int: 0" is not a user class shows in the log file. I am guessing you cannot downcast unless Entity's constructor calls ObjectMesh(fileName). But that means I cannot use engine.world.loadNode() and I'll have to setup the objectmesh with my own loadNode script. Perhaps there is a better way? Link to comment
frustum Posted October 12, 2012 Share Posted October 12, 2012 To initialize extern member you must call base class constructor inside your Entity constructor in this way: Entity(string filename) : ObjectMesh(filename) { } // or Entity(string filename) : ObjectMesh() { extern.load(filename); } This base class construction limits inheritance flexibility because it's impossible to load base class from NodeReference. To remove this restriction a new function called set_extern() will be available in the next SDK: class Entity : ObjectMesh { Entity(string filename) { ObjectMesh m = new ObjectMesh(filename); set_extern(m); } }; This function initializes internal mapping for cast() function if the base class constructor is no called. You can also store your Entity class inside Node Variable via Node::setVariable/getVariable() functions. Link to comment
HarpSeal1 Posted October 16, 2012 Author Share Posted October 16, 2012 Hi Frustum, setVariable works. Although once set_extern() is added to the SDK I will update my code. Thanks for you help, it is much appreciated! Link to comment
