[SOLVED] WidgetSpriteViewport transparence
Is there anyway to make WidgetSpriteViewport behave as WidgetSpriteNode ?
I don't want to have an opaque background instead I would like it to be filled an fully transparent alpha value.
Thanks
Thanks ulf.schroeter, it's seems that I did the same thing that carl.sutton, adding a dummy root for my hierarchy.
I'm agree with you or they should add a better explanation of the deep differences between WidgetSpriteNode and WidgetSpriteViewport.
  • 2 weeks later...
Abou,
  • WidgetSpriteNode supports alpha, since it is used specifically to render separate nodes. It does not support engine postprocesses (like HDR, DOF, motion blur, glow, etc.); only postprocess materials can be applied to it.
  • WidgetSpriteViewport is used to render the whole scene, with all postprocesses. But the composite shader does not support alpha.
I've added this into class descriptions in docs.
