ulf.schroeter Posted October 2, 2012 Share Posted October 2, 2012 Disabling rendering when UNIGINE application is not in the foreground via engine.app.setUpdate(0) is a great way of saving processing power for active application in the forground (e.g. we use interactive UNIGINE data visualization together with Powerpoint presentations for customer demonstrations via beamer). Nevertheless this causes ugly screen artifacts due to missing render buffer refreshes during window moves for uncovered render window parts It would be great if setUpdate() could be configured with an additional option to refresh UNIGINE window while in background mode with the last rendered scene image (still store in one of the internal render buffers?). This shouldn't cost much performance, but would give a much better overall visual impression. Link to comment
manguste Posted October 4, 2012 Share Posted October 4, 2012 That's strange, cannot reproduce it on my Win7. Can you give more details on your configuration so our QA department test it? Link to comment
ulf.schroeter Posted October 4, 2012 Author Share Posted October 4, 2012 That's strange, cannot reproduce it on my Win7. hm, this is strange too ?!? I can reproduce it on every of my WIN 7 machines. Calling engine.app.setUpdate(0) on system init int init() { engine.app.setTitle( "RDE Satellite Communication Monitoring" ); engine.app.setIcon( new Image("rde/textures/icon-app.png") ); engine.app.setUpdate(0); ...... ..... engine.console.run("world_load rde"); return 1; } simply disables update of render window when Unigine applicationn is in background and produces visible artifacts when other windows are moved over this render window (which is quite clear as Unigine rendering is disable when in background) Strange that you cannot reproduce this...may it be possible, that your editor is configured for 'always update' which overides initial system script call to engine.app.setUpdate(0) ? Link to comment
danni.coy Posted October 5, 2012 Share Posted October 5, 2012 Ulf do you have Win7 in classic mode? As I understand it, If a compositor is running it will have an image of the window buffered that it can use to draw over damaged areas, whereas without compositing the application itself has to be responsible for that task. Link to comment
ulf.schroeter Posted October 5, 2012 Author Share Posted October 5, 2012 Dany, good idea ! I will check this Edit: ok, activating Win7 Aero avoids the background artifacts, but this seems to have some performance impacts on 3D rendering when in foreground...but nevertheless at least an option, thanks ! Link to comment
