Igor_de Posted October 1, 2012 Share Posted October 1, 2012 To move objects using PlayerActor, when I add it to the editor in an errors. PlayerActor actor = new PlayerActor(); add_editor(actor); UserArray::push(): unitialized keyEditor::update(): editor update function return 0 Link to comment
manguste Posted October 4, 2012 Share Posted October 4, 2012 Cannot reproduce it - you can add actor into the editor. The error message indicates the actual error is on a different line of your script. Link to comment
Igor_de Posted October 5, 2012 Author Share Posted October 5, 2012 Yes, i can add actor in the editor, but when try see it, the following error occurs. To reproduce it, edit samples\players\actor00.cpp and add in function create_scene add_editor(actor); after that try navigate to actor in Nodes window Link to comment
manguste Posted October 11, 2012 Share Posted October 11, 2012 Ah, my bad. PlayerActor support has been recently added, so you can test it very soon with an updated SDK. Link to comment
