koshman86 Posted September 12, 2012 Share Posted September 12, 2012 I have a DummyNode with a child ObjectMesh, both created via System-script function NewNode(), and the pointers are managed by C++. Child was attached by Unigine::Node::addChild(). I used SetScale() from World script to set parent node scale - all was Ok. BUT. When I moved SetScale() to the System script, it began to set the scale BOTH to parent and child nodes. (C++) - by switching which line, I get different sizes of objects on the scene (of size Scale or Scale^2) ... static void SetScale(NodePtr parentNode, float scale) { //Engine::get()->runSystem("NodeSetScale", Variable("Node",node.get()), Variable(scale)); Engine::get()->runWorld("NodeSetScale", Variable("Node",node.get()), Variable(scale)); } (unigine.cpp) - indeed sets Node's and Node's child scale ... void NodeSetScale(Node node, float scale) { return node.setScale(vec3(scale, scale, scale)); } (Earth.cpp) - indeed sets Node's scale only ... void NodeSetScale(Node node, float scale) { return node.setScale(vec3(scale, scale, scale)); } Link to comment
koshman86 Posted September 18, 2012 Author Share Posted September 18, 2012 Fixed! I found that the C++ NodeSetScale() was run from the World script -called function. Solved like this: (C++) ... Unigine::Engine::get()->pushSystem(); Script::Node::SetScale(node, NewScale); Unigine::Engine::get()->popSystem(); ... now System script callback works fine. Link to comment
