pramod.s Posted September 10, 2012 Share Posted September 10, 2012 Hello, I am trying to remove multiple trigger created by following code And I am using trigger.setEnterCallback(0) to remove the PhysicalTigger but I am facing an issue in removing them. Below mentioned is the scenario. The trigger.setEnterCallback(0); works if I have only one trigger, but when I have more trigger it is not working. int size = 0; for(int x = 0; x <= size; x++) { ObjectMesh mesh = add_editor(new ObjectMesh("TestWork/assest/worlds/meshes/sphere_00.mesh")); mesh.setWorldTransform(translate(Vec3(x, 0, 0.25f))); } For each mesh Object I place an Physical Trigger using my custom object "trigger" over it's location & set respective callback (Enter & Leave) trigger.setEnterCallback("enter_callback", x); Now I am set triggerEnterCallback(0, x) in enter_callback() function after all my operation are done in this function But the trigger is till existing, how can I remove the trigger in above mentioned problem. Thanks Link to comment
pramod.s Posted September 11, 2012 Author Share Posted September 11, 2012 can anyone give suggestion to this!! Link to comment
manguste Posted September 11, 2012 Share Posted September 11, 2012 PhysicalTrigger is node just like any other node in the scene. Meaning you can delete as a node: If you create it in script: delete trigger; If you create it in the world via the editor: engine.editor.removeNode(trigger); Link to comment
