steve.learmonth Posted August 23, 2012 Share Posted August 23, 2012 I'm seeing inconsistent and unexpected behaviour when trying to set variables passed by reference (possibly related to inheritance). See example below: class MyBase { public: void TestSetByReference(int& result) { result = 17; } }; class MyDerived : MyBase { public: void TestSetByReference(int& result) { result = 34; } }; MyBase base = new MyDerived(); MyDerived derived = new MyDerived(); int i = -1; derived.TestSetByReference(i); log.message("derived.TestSetByReference = %d \n",i); i = -1; base.TestSetByReference(i); log.message("base.TestSetByReference = %d \n",i); i = -1; MyBase(base).TestSetByReference(i); log.message("MyBase(base).TestSetByReference = %d \n",i); i = -1; MyBase::TestSetByReference(i); log.message("MyBase::TestSetByReference = %d \n",i); i = -1; MyDerived(base).TestSetByReference(i); log.message("MyDerived(base).TestSetByReference = %d \n",i); i = -1; MyBase(base).TestSetByReference(i); log.message("MyBase(base).TestSetByReference = %d \n",i); // Output: derived.TestSetByReference = 34 base.TestSetByReference = 0 <--- ?? MyBase(base).TestSetByReference = 0 <--- ?? The same call gives a different result below MyBase::TestSetByReference = 17 MyDerived(base).TestSetByReference = 34 MyBase(base).TestSetByReference = 17 <--- ?? Different result, but still wrong Performing the same example except returning by value gives expected results (i.e. result is always 34, except when base class method is explicity called via MyBase:: ) Is this a known bug or limitation? Link to comment
manguste Posted August 23, 2012 Share Posted August 23, 2012 A limitation, alas. It's under investigation, but definitely can't guarantee that a positive result is to be expected. Link to comment
