[SOLVED] BodyFracture and Joint problem
Hello!
I need create fracturing "target". I create cylinder from source code and rotating it (see attaching picture). If player collide with "target" from the bottom, camera is failed (black screen). After command "editor_load" camera don't work too. What I doing wrong?
Attached picture seems to be missing. Best approach for problem resolution is to provide a small test case for problem reproduction. Based on the very short description most probably it will be hard to provide any usefull hints.
First problem solved, but appeared second. Need remove joint and break BodyFracture at the same time.
I can't remove joint in ContactCallback whith BodyFracture (which joint to BodyDummy). In random iterations it's work, as well as createCrackPieces. Source code in attach. Thanks in advance!
test_fracture.rar
your mistake material name.
skinner_agent_body_d ->skinner_agent_body
skinner_agent_head_d ->skinner_agent_head
skinner_agent_eye_d ->skinner_agent_eye
test_fracture.mat
<materials version="1.10">
<material name="skinner_agent_body_d" parent="mesh_base">
<state name="emission">1</state>
<texture name="diffuse">textures/agent_body_d.dds</texture>
<texture name="normal">textures/agent_body_n.dds</texture>
<texture name="specular">textures/agent_body_s.dds</texture>
<texture name="emission">textures/agent_body_e.dds</texture>
<parameter name="base_transform">vec4(2.0f,1.0f,0.0f,0.0f)</parameter>
<parameter name="specular_scale">5</parameter>
<parameter name="fresnel_bias">0.1</parameter>
<parameter name="fresnel_power">2</parameter>
</material>
<material name="skinner_agent_head_d" parent="mesh_base">
<texture name="diffuse">textures/agent_head_d.dds</texture>
<texture name="normal">textures/agent_head_n.dds</texture>
<texture name="specular">textures/agent_head_s.dds</texture>
<parameter name="specular_scale">2.763</parameter>
<parameter name="fresnel_bias">0</parameter>
</material>
<material name="skinner_agent_eye_d" parent="mesh_base">
</material>
<material name="green" parent="mesh_base">
<texture name="diffuse">textures/green_d.dds</texture>
</material>
<material name="red" parent="mesh_base">
<texture name="diffuse">textures/red_d.dds</texture>
</material>
</materials>
