sergey.shandar Posted August 9, 2012 Share Posted August 9, 2012 Hi, I would like my program creates a new "my_library.prop" file. I've found this list of functions https://developer.unigine.com/en/docs/1.0/code/scripting/library/engine/engine.properties I successfully created an empty "my_library.prop" file using engine.properties.addWorldLibrary() function. My question is how can I add a new property to this library? Should I use "engine.properties.cloneProperty()" function? Then, which property should I use to clone? I've tried "node_base" but cloneProperty returns an error "PropertyManager::cloneProperty(): can't clone "node_base" parent property". Thank you in advance for your help. Link to comment
manguste Posted August 14, 2012 Share Posted August 14, 2012 Base properties cannot be cloned or moved. you can only inherit properties from them. engine.properties.addWorldLibrary("property_test/test.prop"); engine.properties.inheritProperty("node_base","property_test/test.prop","my_node_base"); engine.properties.save("property_test/test.prop"); Properties are usually created manually in XML file. If you need to create your properties strictly via scripts, you can open XML file, write data into it and save it. 1 Link to comment
