[SOLVED] how to call engine.console.run script function in C++ function?
hello all,
I call a system script function engine.console.run with some command and parameters in C++ interface Unigine::Engine::runSystem(). I call it like this
string path = "D:\example.world";
engine->runSystem("engine.console.run", Variable("world_reload"), Variable(path));
when executes, the console complain the following errors:
Interpreter::get_extern_function() : can not find "engine.console.run" function with 2 auguments.
the engine.console.run itself is a variable paremeter function with the definition as:
engine.console.run(string command, ...);
so what is the right method to call such script function in a C++ function?
thanks in advance.gine.console.runystem
I call a reload_world command with a path to a world file like this
string str = "D:\example.world";
engine->runSystem("engine.console.run", Unigine::Variable("world_reload"), Unigine::Variable(str));
when execute, the console complain the following errors:
Interpreter::get_extern_function(): can't find "engine.console.run" function with 2 arguments
Interpreter::runFunction(): bad function id 0
so what is the right method to call this function in C++ functions?
thanks in advance!
