[SOLVED] how to export user-defined data to UnigineScript?
Hi all,
In a C++ Plugin I generate a map or vector with different sizes. I want to export these variable to UnigineScript
for later use in world Script, So how to export such user-defined data variables to UnigineScript?
for example: I have the following data in a C++ plugin:
typedef struct mydata {
string name;
int x;
int y;
int z;
}mydata ;
mydata data1[1024];
std::vector<mydata> data2;
std::map<std::string, mydata> data3;
how can i export data1, data2, data3 to UnigineScript and access them from world Script?
Thank you!
Link to post
Thanks you steve3d , The Variable class have only the inbuilt type constructor such as int float vec3 and so on
How to use Variable to export my own datatype mydata data1[1024], for example?
Link to post
And another question, How to export Class with private constructor, for example, some class use singleton mode:
class singleton
static singleton* getInstance();
~singleton();
singleton();
how to export such class to Unigine Script?
Thanks for help.
Link to post
Another question : How to export abstract base class ? (could be useful in some cases)
Link to post
You can declare Unigine::ExternClassConstructor template as a friend class.
class MyClass {
protected:
	template <class> friend class Unigine::ExternClassConstructor_0;
	MyClass() { Log::error("MyClass::MyClass(): called\n"); }
Friend.zip
Link to post
Check this sample: source/samples/Api/Inheritance from SDK.
Link to post
Looks like it was a mistake in my code as it perfectly works now ;)
Sorry for silly question !
Link to post
Hi manguste, when i download the attachment, it pop out an error dialog with the message complaining as follows:
can not download index.php (come from developer.unigine.com)
can not open Internet site. Your requsrted site is unusable or cannot find, please try again later.
Link to post
  • 2 weeks later...
Sorry, on our side everything seems to work fine, so please check for problems on your side (firewall, proxy server issues, etc).
Link to post
