danni.coy Posted July 5, 2012 Share Posted July 5, 2012 It bugs me that this is a modal window is there any technical reason why it has to be? could for example the states and parameters be moved into new tabs in the main Node window when the node has a property? Link to comment
manguste Posted July 5, 2012 Share Posted July 5, 2012 Actually, Properties editor is not a modal one. If you are talking about the one accessed via Nodes -> Surfaces -> Property, it's for per-instance tweaking of a property. It is designed for fast changing of one or two parameters, which will create a separate instance of the current property. And that in its turn should be a rare exception, since swamping the world with property instances is in no way performance friendly. All editing is designed to be done in the Properties editor. Link to comment
