yuwen.xiang Posted April 29, 2012 Share Posted April 29, 2012 My English is very poor. I find nothing code in document whith the Player set the position and viewdirection , example:frist I see A Node(vec3(...)), but now I want to see B Node,I can get B Node( findNode("nodeName")).so I can get B Node vec3,now how can find the B node ViewDirection value. who have code about it . thanks a lot. Link to comment
GeorgeP Posted April 29, 2012 Share Posted April 29, 2012 Hello. Have you tried using the following functions in Player class? void setFov(float fov) void setUp(vec3 direction) void setZFar(float distance) void setZNear(float distance) Link to comment
yuwen.xiang Posted April 29, 2012 Author Share Posted April 29, 2012 Hello. Have you tried using the following functions in Player class? void setFov(float fov) void setUp(vec3 direction) void setZFar(float distance) void setZNear(float distance) Thank you very much. but I don't know that these four paramter value .how and where get.have you example code? Link to comment
GeorgeP Posted April 30, 2012 Share Posted April 30, 2012 Are you familiar with perspective projection ? These 4 parameters are the Player's camera options. check this: http://www.dgp.toronto.edu/~karan/courses/csc418/fall_2002/notes/vvol.html Link to comment
yuwen.xiang Posted May 2, 2012 Author Share Posted May 2, 2012 Are you familiar with perspective projection ? These 4 parameters are the Player's camera options. check this: http://www.dgp.toronto.edu/~karan/courses/csc418/fall_2002/notes/vvol.html sorry! I don't understand the article. (http://www.dgp.toronto.edu/~karan/courses/csc418/fall_2002/notes/vvol.html) Is looking to A(455,345,335). up vec3(0,0,1) far=60,zfar=10000,znear = 0.1 direction vec3(0,0,-1). now I want to look to B(5082,4340,379) . how to get the camera paramters? can you give me a compute formula or code sample. Thank you ! Link to comment
carl.sutton Posted May 2, 2012 Share Posted May 2, 2012 Player player = engine.editor.getPlayer(); vec3 target = vec3(5082, 4340, 379); // B vec3 direction = target - player.getPosition(); mat4 view = lookAt(player.getPosition(), direction, player.getUp()) player.setModelview(view); Link to comment
yuwen.xiang Posted May 3, 2012 Author Share Posted May 3, 2012 thanks a lot! Now i want to ask a question , How can move the camera to B(node) or close with B(node)? because the camera see B is very little dot. have you any method to change the camera position . so . The viewer can look a very big and clear B node. Link to comment
unclebob Posted May 3, 2012 Share Posted May 3, 2012 Hello, You should call setPosition method to change camera position. Here is modified Carl's code sample: Player player = engine.editor.getPlayer(); player.setPosition(5000, 4200, 300); // place camera near node B vec3 target = vec3(5082, 4340, 379); // B vec3 direction = target - player.getPosition(); mat4 view = lookAt(player.getPosition(), direction, player.getUp()) player.setModelview(view); Also, please read this topics: https://developer.un...rs/class.player https://developer.un...odes/class.node Link to comment
yuwen.xiang Posted May 3, 2012 Author Share Posted May 3, 2012 thank you ! Hello, You should call setPosition method to change camera position. Here is modified Carl's code sample: Player player = engine.editor.getPlayer(); player.setPosition(5000, 4200, 300); // place camera near node B vec3 target = vec3(5082, 4340, 379); // B vec3 direction = target - player.getPosition(); mat4 view = lookAt(player.getPosition(), direction, player.getUp()) player.setModelview(view); Also, please read this topics: https://developer.un...rs/class.player https://developer.un...odes/class.node Thank you very much! Link to comment
