Rob Posted April 6, 2012 Share Posted April 6, 2012 I just tried the terrain grabber and I was wondering why my detail materials are not baked into the texture It does grab all of the objects placed on the terrain but the detail materials are being left out Im using grabber with the new overlap detail material blend mode, could it be possible that the overlap detail materials arent added to grabber yet? Link to comment
unclebob Posted April 9, 2012 Share Posted April 9, 2012 Hi Rob, Engine need some 'warm up' to render overlap detail materials. When grabber tries to render all your stuff to a texture, some overlap materials might not being rendered. Try to set render frames to 3 in grabber parameters. Also, try to increase distance scale before grabbing (this can slow down your performance). Does it solve your problem? Link to comment
Rob Posted April 10, 2012 Author Share Posted April 10, 2012 I set the distance scale to 50 and the render frames to 3 but it still doesnt seem to grab the detail materials Any other things I could try? I just tried to grab the lightmap for the terrain but this gives very strange results too Everything seems to be divided into different surfaces for some reason, so im guessing my settings are wrong but I cant seem to figure out what Link to comment
unclebob Posted April 11, 2012 Share Posted April 11, 2012 Hi again, Rob. Could you provide your scene and some screenshots which describes your problem? Link to comment
Rob Posted April 11, 2012 Author Share Posted April 11, 2012 here is a screenshot, dont think I can send the scene atm the project folder is about 4gb As you can see in the screenshot I am using a simple sand detail material, the brown you see is the diffuse color of the terrain so when I use grabber I want it to take the detail materials but for some reason these are being ignored As you can cleary see in the screenshot the shape on the terrain is fading under the detail material while in grabber it isnt faded at all as you can see in the small grabber thumbnail Link to comment
unclebob Posted April 11, 2012 Share Posted April 11, 2012 Thanks, Rob. :) We'll do investigation and report back soon. Sorry for forcing you to wait. Link to comment
Rob Posted April 11, 2012 Author Share Posted April 11, 2012 np, I hope you guys can figure this out Link to comment
manguste Posted April 26, 2012 Share Posted April 26, 2012 Rob, actually, there's no problem with the Grabber :) Simply increase the Lods distance (Distance scale has no influence over it!) and the grabber will bake the diffuse together with detail materials. A little bit of gritty details, if you are interested in them. To bake a terrain-wide diffuse, per-surface textures are baked separately, one by one, as if a camera is placed right above the center of each surface. This is done to bake view-dependent detail textures (they are seen only on 1-4 LOD levels) and WorldClutter, WorldCluster, etc.(they place nodes only around the camera). Link to comment
manguste Posted April 26, 2012 Share Posted April 26, 2012 And if you get strange tiles or stripes on the resulting lightmap, disable HDR (because if HDR is enabled, each per-surface camera is baked with different lighting conditions). I'll add this to docs. Link to comment
Rob Posted April 26, 2012 Author Share Posted April 26, 2012 Increasing the LOD distance worked like a charm! Exactly what I needed. Thanks! Link to comment
