marc.jamero.ph Posted April 3, 2012 Share Posted April 3, 2012 I'd like to create new sets of widget(i.e. WidgetInventory) via a plugin. Is it possible? If yes, how exactly can it be done? To make things clear, an Inventory Widget consists of let's say, 3 buttons, 1 listbox and a sprite. WidgetButton WidgetListBox WidgetSprite There, I need those Widgets to use inside the DLL Project using C++ via the C++ API and produce a plugin. In other words, I want to make a new WidgetInventory by using the default Widgets like WidgetButton in the form of a plugin. Link to comment
unclebob Posted April 3, 2012 Share Posted April 3, 2012 Hi, You can't inherit from classes like Nodes, Widgets, etc. on C++ side. But you can extend them from UnigineScript. Please read this topics for additional information: 1) https://developer.unigine.com/forum/topic/1228-user-object-node-type 2) https://developer.unigine.com/forum/topic/1238-set-worldtrigger-callbacks-within-user-class-instance Link to comment
marc.jamero.ph Posted April 10, 2012 Author Share Posted April 10, 2012 I have linked my C++ project to the C++ API and to the Unigine source. but I think Widgets are not exported out on the .dll right? that's why I can't make a plugin that will add Widgets like for example WidgetInventory. Link to comment
marc.jamero.ph Posted April 10, 2012 Author Share Posted April 10, 2012 Is there any other way to access the core classes(widgets,nodes) using C++ aside from modifying the source of the Unigine? Link to comment
unclebob Posted April 11, 2012 Share Posted April 11, 2012 No, you can't inherit without modifying the source. You can extend widgets/nodes/etc. in four different ways: 1. (C++ side, unlikely) Modify engine source and inherit you classes from original Widget/Node 2. (Unigine script) Inherit from extern 'Widget' class provided by C++ part 3. (Unigine script) Write custom wrapper class on one of currently available widgets (for example, buttons in Oil Rush is a custom wrapper on WidgetSprite class) 4. (Unigine script) Inherit from core/systems/widgets Widget class Link to comment
