[SOLVED] Center text in WidgetButton
Hi all,
I want to set a button text in a centered paragraph multiple. The code is as follows:
<ui version="1.0">
<window name="window" export="1" space="4" sizeable="1" width="512">
 <text>mimicGui</text>
 <hbox space="3">
  <button>
<text align="center">DESCARGA BAT.
EN EL MAR SIN AIP</text>
  </button>
  <button>
EN LA MAR CON AIP</text>
  </button>
  <button>
<text align="center">CARGA BAT. CON
DAR'S (PUERTO O MAR)</text>
  </button>
  <button>
EN PUERTO SIN AIP</text>
  </button>
  <button>
<text align="center">CARGA BAT. EN
PUERTO SIN DAR'S</text>
  </button>
 </hbox>
</window>
</ui>
The result, as you can see in the image it's a centered text, but not a centered paragraph:
What I'm doing wrong?
Regards,
Iván.
Try something like this, I assume it will work although I havn't tried myself
<button>
<text rich="1">
<center>DESCARGA BAT.EN EL MAR SIN AIP</center>
</text>
</buuton>
With a little change...
  <button>
   	<text rich="1">
     	<center>DESCARGA BAT.</center>
     	<center>EN LA MAR CON AIP</center>
       </text>
  </button>
It works!
Thank you Carl.
