ulf.schroeter Posted March 5, 2012 Share Posted March 5, 2012 New Unigine script interpreter documentation under https://developer.unigine.com/en/docs/1.0/tools/interpreter/ should give a hint that script should implement main function as entry point void main() { ...... } Also ist would be helpful to rename the documentation topic from 'interpreter' to 'USC interpreter' to be consistent with other cross-references / forum entries always using USC abreviation. USC interpreter help message should also be changed from 'run script: usc_x86 script.cpp' to 'run script: usc_x86 script.usc for consistency reasons. Finally a short example for proper command-line argument handling would be very helpful for new users. Link to comment
unclebob Posted March 6, 2012 Share Posted March 6, 2012 Hi, Thanks for your help. Here is two samples. I think Nadezhda (manguste) will put them into docs. 1. Print all command line args #!/usr/bin/env usc /* */ void main() { forloop(int i = 0; getNumArgs()) { log.message("Arg [%d]: %s\n",i,getArg(i)); } } 2. Fill some variables and set flags through command line args #!/usr/bin/env usc int value1 = 0; int value2 = 0; int use_flag = 0; /* */ void main() { for(int i = 0; i < getNumArgs(); i++) { string arg = getArg(i); if(arg == "-set_value_1") { if(i + 1 >= getNumArgs()) { continue; } value1 = int(getArg(++i)); continue; } if(arg == "-set_value_2") { if(i + 1 >= getNumArgs()) { continue; } value2 = int(getArg(++i)); continue; } if(arg == "-use_flag") { use_flag = 1; } } log.message("value1: %d\nvalue2: %d\nflag: %d\n",value1,value2,use_flag); } Link to comment
frustum Posted March 6, 2012 Share Posted March 6, 2012 Another example is: utils/Upgrade/terrain.usc Link to comment
manguste Posted March 11, 2012 Share Posted March 11, 2012 Ulf, really good remarks! Renamed, plus examples are added (thanks to Bob :) Link to comment
