binstream Posted February 27, 2012 Share Posted February 27, 2012 Render: Added ObjectMeshCluster. Mesh Cluster is a highly optimized way to render a great number of identical meshes with the same material in the world. These meshes are baked and managed as one object, which substantially speeds up rendering. Added ObjectMeshClutter. Mesh Clutter scatters identical meshes across the world or terrain and speeds up their rendering. Meshes can not only be scaled, but also randomly scaled and oriented (but not moved), if necessary. Mesh Clutter scatters objects procedurally, and renders them only around the camera. It allows to render even a large number of meshes while keeping performance high. Added ObjectBillboards object suitable for fast rendering of groups of billboards (stars, clouds and so on). Fixed WorldCluster save/restore system. Improved GPU detection in Mac OS X. Restored gamma value control in Linux. Improved support of NVIDIA 3DVision. Improved support of Intel HD 3000 GPU. Fixed skinned mesh instancing in Direct3D10/11. Added a new mesh_layer_base material. It allows for selective blending of two materials: it operates on two sets of textures that show through according to a mask. Added a new mesh_triplanar_base material. It allows to texture meshes without using UV texture coordinates. Textures are simply projected onto a mesh along three axes. Added an optional material option to animate grass when 'Clutter' shape is used for it. Fixed non-square mipmaps compression issue. Added 'auto' value for 'video_app' console variable (the engine sets the best of available APIs). Fixed disappearing of shadows in stereo 3D mode. Better detection of GLX_ARB_create_context extension support (improved MESA compatibility on Linux). Added vertical and horizontal flip functions for Image. Safer way to restore fullscreen video mode after focus change in Windows. Fixed issue with non-attached deflector position for particle systems. Added 'Angle fade' option for mesh_leaf_base material to hide polygons wich are currently perpendicular to the screen plane. Adjustable number of generated cells for grass and clutter objects. Improved fullscreen mode setting in Linux and Mac OS X. Added 'Shadow radius' parameter to terrain, grass, cluster nodes. It controls the distance outside the view frustum used to render polygons to avoid disappearing shadows. It is 0 by default ('radius' parameter in WorldCluster is now gone, please set up this one instead). More configurable render_composite material: you can render non-blurred objects by mask with DOF or motion blur enabled using the Auxiliary buffer. Fixed rendering of two-sided objects into deferred buffer. Removed render_use_specular console variable. Added 'spherical' flag for sky (the sky is a full sphere mesh instead of a hemi-sphere, if enabled). Improved light scattering when used together with a background cubemap. Added render_use_shadow_kernel console variable (set it to 0 to improve shadow rendering performance). Improved shadows quality on 'high' shaders profile. Terrain: Per-surface control of flatness threshold for terrain. Changed format of terrain files (.ter); please use utils/Upgrade/terrain.usc script for conversion (USC interpreter is required, see below). Removed tesselated terrain material. Optional ambient lighting for terrain which allows to disable a world light pass and render terrain in a single ambient pass. No shadows can be cast on the terrain in this case, though. Fixed triplanar shading for terrain. Optimized terrain shading. GUI: Added a scroll bar in WidgetComboBox. Reduced TTF atlas texture size. Added IME support into the Interface plugin. Reduced memory consumption by widgets to a small degree. Added 'dynamic' flag for WidgetSprite images that are frequently updated in runtime. Faster video playback. Added 'changed' callback for paned containers and WidgetScrollBox. Added setMouseEnable() function to control rendering of the mouse. Physics: Fixed continuous collision response. Added CCD for PhysicalTrigger, BodyParticles, BodyCloth and BodyRope. Sound: Fixed seeking on WAV files. Fixed bug in libvorbis library for Mac OS X. Added 'auto' value for 'sound_app' console variable (the engine sets the best available API). Correct playback of short streamed sounds. UnigineScript: Stack size is increased to 2048 elements. Added '#pragma no_optimize' support. Support of up to 6 arguments for console commands called from a script. Other: Fixed path to cache directory. Updated Xcode project for iOS. Added clipboard support in Mac OS X. Added filesystem_mmap console variable (set to 0 to disable memory-mapped files). Added file name modifiers system. Read the original idea. Added a new NodeTrigger node type. It fires callbacks when enabled/disabled or moved, which is useful to control objects inside of WorldClutter and WorldCluster). Added memory_save console command for dumping memory pools (useful for offline analysis). Added 'compaction' flag for meshes that prevents a mesh copy from being stored in system memory (making no intersection or collision possible with it). This option is highly useful for PlayStation 3. Tools: Added toggling of channels in ImageView (R, G, B, A hotkeys). Added one-way NodeReference collector into WorldCluster (very useful for final content optimization). See "Collector" tab in WorldCluster node. File name for SoundSource is now displayed in UnigineEditor. Added standalone UnigineScript interpreter (USC tool, see below). Added AlphaMapper tool into ResourceEditor for baking high-quality alpha test textures based on high-poly mesh geometry. Fixed mesh overlapping visualization in ResourceEditor. Fixed MD5B mesh format import. Improved terrain creation in UnigineEditor. Support of the normal map import for terrain. Added optional Y-axis texture flipping on terrain data import. Added baking of objects into diffuse, normal or lightmap textures for terrain. See "Grabber" tab in ObjectTerrain node. Tools/Interface tab in UnigineEditor is moved into Tools/Common. Backup of a NodeRefence file is now stored in UnigineEditor when edited. Added world profiler (shows node, body and joint count), 'show_profiler 3' console command. Standalone UnigineScript interpreter (USC tool) The stand-alone interpreter (called USC due to its script file extension) allows for making Unigine scripts into executable programs that are run directly from the environment or from the command-line. As the interpreter works independently, it offers an easy way for developers to extend the functionality and solve the specific or recurring tasks for which it is not necessary to create a separate executable application. The tool supports the following: Everything from the Core library of UnigineScript (can be used to read/write files, parse XML files, handle images, perform mathematical calculations, etc). Meshes. Load and save a mesh, modify or clear all its data. You can add and set transformation to mesh surfaces, as well as change position, normal vectors and texture coordinates for separate vertices. Skinned meshes. Just like in case with simple meshes, you can get access and modify surface and vertex data for skinned meshes. Data on bones of the rig is also exposed. Support of multiple CLI arguments. Source code of the stand-alone interpreter can be found under source/tools/Interpreter, it is included into ToolsPack. PS: Unigine-powered Oil Rush naval strategy game has been released for Windows, Linux and Mac OS X. Its sources are available for Unigine customers as a reference project. Download links All files can be found in "Downloads" section of the portal: https://developer.un...ileserver/index Link to comment
pascal.winistoerfer Posted February 27, 2012 Share Posted February 27, 2012 Good Update Hope the terrain merge runs smoth :) also, the ability to import normal map for terrain now is great. the billboard clustering for stars and clouds etc - is that more accurate then placing them manual i guess? in the past, you could just spread the billboards in a dummy node via normal cluster/clutter. It would be cool if you guys could take a look in this also: https://developer.unigine.com/forum/topic/1092-3ds-max-export-plugins-feature-extension/ https://developer.unigine.com/forum/topic/1091-ragdoll-sanim-files-ignoring-scaling/ And congrats to oilrush release B) cheers Link to comment
ivan.cuevas Posted February 27, 2012 Share Posted February 27, 2012 USC Tool... cool... :) Link to comment
milad.salehi Posted February 28, 2012 Share Posted February 28, 2012 Nice Job! Thanks. Link to comment
Rob Posted February 28, 2012 Share Posted February 28, 2012 Thanks for the update! 1 thing the posted images dont work Link to comment
binstream Posted February 28, 2012 Author Share Posted February 28, 2012 Images fixed. Link to comment
Rob Posted February 28, 2012 Share Posted February 28, 2012 How do you convert the terrain exactly? I just pointed the terrain.usc to the usc_x86.exe but what do i do with my terrain? It just opens a msprompt window and then closes again, am I missing something? Link to comment
frustum Posted February 28, 2012 Share Posted February 28, 2012 usc.exe terrain.usc my_terrain.ter Link to comment
alexei.garbuzenko Posted February 28, 2012 Share Posted February 28, 2012 More configurable render_composite material: you can render non-blurred objects by mask with DOF or motion blur enabled using the Auxiliary buffer. how? I see aux color setting in material, but no tips or masks for motion blur itself. Link to comment
alexei.garbuzenko Posted February 28, 2012 Share Posted February 28, 2012 It's really amazing how perfect is new ObjectMeshCluster interface in editor! I was also shocked how easy we can migrate from our obsolete WorldClusters to new mesh-based cluster! (sarcasm) p.s. Unigine GUI and editor always were not very friendly (some sort of programmers graphics?), but with this update you've earned top place in the charts.. Link to comment
Rob Posted February 28, 2012 Share Posted February 28, 2012 nvm I made a mistake Delete this please Link to comment
frustum Posted February 28, 2012 Share Posted February 28, 2012 how? I see aux color setting in material, but no tips or masks for motion blur itself. Use "render/auxiliary_02" sample as an example. Link to comment
frustum Posted February 28, 2012 Share Posted February 28, 2012 It's really amazing how perfect is new ObjectMeshCluster interface in editor! I was also shocked how easy we can migrate from our obsolete WorldClusters to new mesh-based cluster! (sarcasm) p.s. Unigine GUI and editor always were not very friendly (some sort of programmers graphics?), but with this update you've earned top place in the charts.. This conversion can be done in three steps: * create ObjectMeshCluster nodes for target meshes, you should assign materials to surfaces. * expand WorldCluster you have in the world. * collect ObjectMeshCluster instances by pressing the corresponded button in the editor. Link to comment
alexei.garbuzenko Posted February 28, 2012 Share Posted February 28, 2012 This conversion can be done in three steps: * create ObjectMeshCluster nodes for target meshes, you should assign materials to surfaces. * expand WorldCluster you have in the world. * collect ObjectMeshCluster instances by pressing the corresponded button in the editor. we have existing clusters with Nodes, not Meshes, so 'Collect' founds no meshes at all. Fixed rendering of two-sided objects into deferred buffer. Works for regular meshes, but not for ObjectMeshCluster/ObjectMeshClutter. Link to comment
frustum Posted February 28, 2012 Share Posted February 28, 2012 we have existing clusters with Nodes, not Meshes, so 'Collect' founds no meshes at all. Collector can grab NodeReference which contains single target mesh. Works for regular meshes, but not for ObjectMeshCluster/ObjectMeshClutter. Two-sided object works slower than geometry with duplicated polygons. Link to comment
steve3d Posted February 28, 2012 Share Posted February 28, 2012 Does ObjectMeshCluster support LOD and ObjectMeshDynamic? Link to comment
alexei.garbuzenko Posted February 28, 2012 Share Posted February 28, 2012 Collector can grab NodeReference which contains single target mesh. does not work. Link to comment
Guest shane.ploenges Posted February 29, 2012 Share Posted February 29, 2012 New features like this ObjectmeshCluster are pretty impossible to use without some good documentation and examples. I went to try it out and could not find a corresponding GUI button in the editor to add this system anywhere, so what is the workflow to generate meshcluster systems randomly then? For example, i thought what this would be is similar to worldcluster, in that you add it from the editor then generate add nodes and a mask and generate random placement then bake the nodes. However this is obviously not the case as i cannot find any way to add an ObjectMeshCluster from the editor. The documentation does not make it clear at all what the work flow is - it only descibes the class itself in programmers terms, not terms of an artists work procedures, which seems to be the case for a lot of Unigines editor tools. The tutorials have not even been updated to reflect the new changes to terrain or worldcluster/clutter, making it even more confusing. Link to comment
Rob Posted February 29, 2012 Share Posted February 29, 2012 New features like this ObjectmeshCluster are pretty impossible to use without some good documentation and examples. I went to try it out and could not find a corresponding GUI button in the editor to add this system anywhere, so what is the workflow to generate meshcluster systems randomly then? For example, i thought what this would be is similar to worldcluster, in that you add it from the editor then generate add nodes and a mask and generate random placement then bake the nodes. However this is obviously not the case as i cannot find any way to add an ObjectMeshCluster from the editor. The documentation does not make it clear at all what the work flow is - it only descibes the class itself in programmers terms, not terms of an artists work procedures, which seems to be the case for a lot of Unigines editor tools. The tutorials have not even been updated to reflect the new changes to terrain or worldcluster/clutter, making it even more confusing. Did you read this: https://developer.un...s/mesh_cluster/ Just go to Add an object > Cluster mesh It works pretty well, I just tested the ObjectmeshCLutter and the performance seems better than the regular clutter, only issue is that it only works with 1 mesh Link to comment
steve3d Posted March 1, 2012 Share Posted March 1, 2012 does not work. tested, it did work, collected objects need to expand to see them. Link to comment
steve3d Posted March 1, 2012 Share Posted March 1, 2012 Now we have ObjectMeshCluster/Clutter and ObjectBillboards, it seems all the prerequests of forest rendering are ready, so is that true that we might see the new vegitation system on next update? Link to comment
alexei.garbuzenko Posted March 1, 2012 Share Posted March 1, 2012 tested, it did work, collected objects need to expand to see them. well, you are the lucky one. It fails to work in my case without any messages, etc. Just ignores the nodes. Link to comment
manguste Posted March 1, 2012 Share Posted March 1, 2012 well, you are the lucky one. It fails to work in my case without any messages, etc. Just ignores the nodes. Retested again and it's still working. Are sure you have assigned the same material to the MeshCluster as to reference nodes? And mesh is the root in your node references? Alexei, if you send us your node reference that might actually help to find out where things are going wrong :) Link to comment
alexei.garbuzenko Posted March 1, 2012 Share Posted March 1, 2012 Retested again and it's still working. Are sure you have assigned the same material to the MeshCluster as to reference nodes? And mesh is the root in your node references? Alexei, if you send us your node reference that might actually help to find out where things are going wrong :) I'm not sure of material cause I never thought it could search by material, but not for mesh name. I'll try one more time and if there are still issues, I'll send you whole world to hunt for this and other issues (random crashes, locked .ter file, visual bugs, etc.) Link to comment
adam.strzelecki Posted March 8, 2012 Share Posted March 8, 2012 Does this release support OpenGL Core Profile 3.2 on Mac OS X 10.7 Lion? This realease seems to be in par with latest Heaven Benchmark, which has Lion 10.7+ support in the News, however launching the demo I am still on old OpenGL 2.1 Compatibility Profile. Can you guys explain what exactly this 10.7+ support means? "Added Mac OS X version compatible with 10.7+ (no tessellation)." Link to comment
