travis.trigg Posted February 5, 2012 Share Posted February 5, 2012 I am working on making a node move to a destination. I am following the route_02 example and trying to replicate that. For some reason I cannot get it to work. I instance the route, do the updates, and it never seems to hit "if(_route.isReached()) {". Please note I am still using the scratch project. Here are the two important classes: level1.cpp #include <unigine.h> #include <core/scripts/utils.h> #include <scripts/MousePicking.h> #include <scripts/MovingObject.h> UserInterface ui; // User interface that loads the UI file // Widgets that will be automatically constructed on loading menu.ui. To be // exported into the script, they should be declared in the global scope. WidgetWindow level_window; // Menu window Node droid; // Droid node float rotation_speed = 50.0f; // Speed of Droid rotation MovingObject box1; // Box1 node, this will contain it Vec3 offset = Vec3(0.0f,0.0f,0.0f); void init_gui() { // Get the default GUI used by the engine. Gui gui = engine.getGui(); // Load all widgets from user interface file. ui = engine.gui.addUserInterface(gui,"project/level1.ui"); // Calculate window size. It is necessary to properly position a widget in // the same frame. level_window.arrange(); // Position the window in the left bottom corner of the screen. level_window.setPosition(0,gui.getHeight() - level_window.getHeight()); // Add the window to be rendered in the default GUI. Only root widgets // should be added (their children will automatically become visible). // The window is movable. gui.addChild(level_window,GUI_ALIGN_OVERLAP); // Set focus to the window. level_window.setFocus(); } void init_nodes() { // Find a node loaded into the editor from level1.world by its name and // get its index. int index = engine.editor.findNode("Droid"); if(index != -1) { // Get the node by its index. droid = engine.editor.getNode(index); } // Make box1 move index = engine.editor.findNode("Box1"); if (index != -1) { box1 = new MovingObject(engine.editor.getNode(index)); } box1.setDestination(vec3(100.0f,0.0f,100.50f)); // Create a free-flying camera to be used in-game. PlayerSpectator camera = new PlayerSpectator(); // Set its position used when the world is loaded. camera.setPosition(vec3(2.0f,0.0f,1.5f)); // Set the viewing direction. camera.setDirection(vec3(-1.0f,0.0f,-0.5f)); // Set the created camera to render the world when in-game mode. It is necessary // because the Editor uses its own separate camera. engine.game.setPlayer(camera); } /* */ // Callback function executed when "Return to Main menu" button from level1.ui is // pressed. void quit_to_main_menu_clicked() { // Call a system script function that displays a splash screen. engine.system.call("setMenuSplash"); // Run the console command that shuts down this world and loads the Menu one. engine.console.run("world_load project/menu"); } Node add_editor(Node node) { engine.editor.addNode(node); return node_remove(node); } void remove_editor(Node node) { engine.editor.removeNode(node); } /* */ // This function is called when the world is loaded. int init() { //init_gui(); init_nodes(); // update scene, used for mouse picking - this is imported from MousePicking.h if(is_function("update_MousePicking")) { thread("update_MousePicking"); } // Add the pathfinding details NavigationSector navigation = add_editor(new NavigationSector(vec3(1024.0f,1024.0f,256.0f))); navigation.setWorldTransform(translate(Vec3(0.0f,0.0f,0.0f) + offset)); return 1; } // This function is called when the world is exited. int shutdown() { // Remove a user interface instance and delete all its widgets from the memory. //engine.gui.removeUserInterface(ui); return 1; } // This function is called each frame while the world is running. int update() { // Rotate the Droid node around Z axis with correction for the game FPS. droid.setTransform(droid.getTransform() * rotateZ(rotation_speed * engine.game.getIFps())); // Update box1 box1.update(); return 1; } and this is MovingObject.h: #include <unigine.h> #include <core/scripts/utils.h> class MovingObject { /*----------------------------------------------- Local Variables -----------------------------------------------*/ // this is the controlled object Node _myControlledNode; // We need to know if an object can be interactive or not // assume that objects aren't until they are set to interactive int _interactive = -1; // The sphere used to detect collisions Obstacle _boundingSphere; // The path for the object to follow, it can be null PathRoute _route; // Show the route in 3d for users to see int _showRoute = 1; // Route destination Vec3 _routeDestination; // Counter for nodes in path int counter; /*----------------------------------------------- Constructor / Destructors -----------------------------------------------*/ // Default constructor takes the object being handled MovingObject(Node node_) { _myControlledNode = node_; //_boundingSphere = new ObstacleSphere(node_.getBoundRadius()); //_myControlledNode.addChild(_boundingSphere); _route = new PathRoute(2.0f); //_route.setExcludeObstacles((_boundingSphere)); } // Deconstructor to remove objects ~MovingObject() { //delete _myControlledNode; // I don't think we need this delete _boundingSphere; delete _route; } /*----------------------------------------------- Methods -----------------------------------------------*/ // Can the object be interacted with by the user? Default is no int isInteractive() { return _interactive; } // Set route for the object to follow void setRoute(PathRoute route_) { _route = route_; } // Instruct the object to go to the destination void setDestination(Vec3 destination_) { engine.world.updateSpatial(); _route.create3D(_myControlledNode.getWorldPosition(), destination_); _routeDestination = destination_; } // this object was clicked by the user void clicked() { if (_interactive) { // do stuff here } } // Update the object void update() { Vec3 position = _myControlledNode.getWorldPosition(); quat orientation = _myControlledNode.getWorldRotation(); //engine.message("Route.isReady() = " + _route.isReady() + ", Route.isReached() = " + _route.isReached() + ", Route.getNumPoints() = " + _route.getNumPoints()); //engine.message("Destination: " + _routeDestination.xyz); if(length(position - _routeDestination) < 2.0f || counter++ > 9000) { if(counter > 9000) engine.message(""); //": PathRoute failed, too far\n"); } else if(_route.isReady()) { if(_route.isReached()) { // get the frames per second float ifps = engine.game.getIFps(); // determine direction object should point Vec3 direction = _route.getPoint(1) - _route.getPoint(0); engine.message(direction.xyz); if(length(direction) > EPSILON) { orientation = lerp(orientation, quat(setTo(Vec3_zero, direction, vec3(0.0f, 0.0f, 1.0f))), ifps * 8.0f); } position += _myControlledNode.getWorldDirection() * ifps * 16.0f; _myControlledNode.setWorldTransform(translate(position) * orientation); if(_showRoute) _route.renderVisualizer(vec4_one); // move to the next node _route.create3D(position, _routeDestination, 1); } else { //engine.message("route has not been reached\n"); } } else if(_route.isQueued() == 0) { _route.create3D(position, _routeDestination, 1); } } }; Any help in understanding the pathfinding system, or maybe something that I am missing, would be GREATLY appreciated! Link to comment
travis.trigg Posted February 6, 2012 Author Share Posted February 6, 2012 This is working now.. Works on one computer, but not another.. weird. I will investigate and figure out why Link to comment
