[SOLVED] Adding JavaFX 2.0 Capability to Unigine over JNI
Hello , i want to add some of my JavaFX addons to my engine.
But there is some problems ,
I donno how to access HWND on Windows side to embed my javafx code.
Can someone help how to access HWND on C++ side?
No way , i think you are giving script side solution here is my code on visual studio :
/* Copyright © 2005-2011, Unigine Corp. All rights reserved.
* File: main.cpp
* Desc: Unigine application
* Version: 1.01
* Author: Alexander Zaprjagaev <frustum@unigine.com>
* This file is part of the Unigine engine (http://unigine.com/).
* Your use and or redistribution of this software in source and / or
* binary form, with or without modification, is subject to: (i) your
* ongoing acceptance of and compliance with the terms and conditions of
* the Unigine License Agreement; and (ii) your inclusion of this notice
* in any version of this software that you use or redistribute.
* A copy of the Unigine License Agreement is available by contacting
* Unigine Corp. at http://unigine.com/
#include <Unigine.h>
#include <UnigineInterpreter.h>
// 1. Create an extern function that receives a script node as a smart pointer NodePtr
void my_node_set(NodePtr node) {
// 1.1. Call the node member function exposed through the C++ API
node->setTransform(translate(vec3(1.0f,2.0f,3.0f)));
int main(int argc,char **argv) {
Engine *engine = Engine::init(UNIGINE_VERSION,argc,argv);
engine->main();
Engine::shutdown();
return 0;
how to reach HWND on C++ side?
i will push java virtual machine on there and need to access
raw OpenGL.
Unigine::App is a C++ API class:
#include <UnigineApp.h>
 HWND window = (HWND)App::get()->getHandle();
 do_smth_with_window(window);
 engine->main();
 Engine::shutdown();
I've added but had problem :HWND window = (HWND)App::get()->getHandle();
1>------ Build started: Project: main_vc2010, Configuration: Debug Win32 ------
1>Build started 08/02/2012 23:38:02.
1>InitializeBuildStatus:
1> Touching "Debug\main_vc2010.unsuccessfulbuild".
1>ClCompile:
1> main.cpp
1>main.cpp(47): error C2027: use of undefined type 'Unigine::App'
1> C:\UnigineSDK\include\Unigine.h(36) : see declaration of 'Unigine::App'
1>main.cpp(47): error C2227: left of '->getHandle' must point to class/struct/union/generic type
1> type is ''unknown-type''
1>main.cpp(47): error C3861: 'get': identifier not found
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:00.58
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Are you absolutely sure that you've included UnigineApp.h? You can check source/plugins/Interface/Interface.cpp for reference, where the handle is returned without any problem.
I've tried this:
/* Copyright (C) 2005-2011, Unigine Corp. All rights reserved.
* File:	main.cpp
* Version: 1.01
#include <Windows.h>
void do_smth_with_window(HWND hWnd) {
//HWND window = (HWND)Unigine::App::get()->getHandle();
//App* app = Unigine::App;
//do_smth_with_window(window);
//engine->getAppPath();
engine->main();
//engine->getAppPath() setIcon(new Image("my_icon.png"));
//engine->runConsole("");
//Engine::main();
//engine.app.setIcon(new Image("my_icon.png"));
//engine.console.setLock(1)
Engine::shutdown();
return 0;
When i try to compile code up , i've got this error on compilation:
1>------ Rebuild All started: Project: main_vc2010, Configuration: Debug Win32 ------
1>Build started 25/02/2012 17:03:50.
1>_PrepareForClean:
1> Deleting file "Debug\main_vc2010.lastbuildstate".
1>ClCompile:
1> main.cpp
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:00.55
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
* File: main.cpp
* Version: 1.01
#include <UnigineImage.h>
#include <UnigineApp.h> //<-- included this but same problem persists
// 0. ImagePtr must be defined as a global variable
ImagePtr image;
// 1.1. Create an image in the Unigine memory pool through ImagePtr smart pointer
ImagePtr my_image_create_0() {
image = Image::create();
// 1.2. Specify parameters of the image and fill it with black color
image->create2D(128,128,Image::FORMAT_RG8);
return image;
// 2. Register the function for export into Unigine
Interpreter::addExternFunction("my_image_create_0",MakeExternFunction(&my_image_create_0));
//HWND window = (HWND)App::get()->getHandle();
//const char *datapath = engine->getDataPath();
//printf("Data path:");
//printf(datapath);
engine->main();
//Engine::main();
Engine::shutdown();
return 0;
1>------ Rebuild All started: Project: main_vc2010, Configuration: Release Win32 ------
1>Build started 27/02/2012 18:13:55.
1>_PrepareForClean:
1> Deleting file "Release\main_vc2010.lastbuildstate".
1> Touching "Release\main_vc2010.unsuccessfulbuild".
1>ClCompile:
1> main.cpp
1>main.cpp(64): error C2039: 'getHandle' : is not a member of 'Unigine::App'
1> C:\UnigineSDK\include\UnigineApp.h(32) : see declaration of 'Unigine::App'
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:00.61
What SDK version do you use? Check include/UnigineApp.h, there should be the following function:
virtual void *getHandle() = 0;
If not, you need a later version: getting a window handle via this function was added at your request in 2011-12-28 SDK.
  • 6 months later...
only the latest SDK version is available for download. It's a good idea to have a local backup copy of each version. Matching SDK documentation for each version can always be found in <SDK>\docs folder.
