WidgetVBox and WidgetHBox border
Hello
I play around with the WidgetVBox and WidgetHBox elements.
In my use case there is already a sprite as background and for separating the elements (WidgetIcons in a WidgetGroupBox).
I now trying to remove the 1 px border for the Box elements, but I can't find any method for this in the documentation.
Is there a way to remove this border?
Kind regards
Manuel
Try the following way after gui is loaded from ui file: call the Widget::arrange() function which visually re-arranges the widget and its children to lay them out neatly
Hi extaliones
Thanks for the tip, but is does not work:
WidgetHBox with WidgetGroupBox as child and sprite as background (child from gui):
WidgetHBox with WidgetGroupBox as child without sprite:
Edit:
The border is linked somehow with the WidgetGroupBox, not the WidgetHBox sorry.
Kind Regards
Manuel
Hi extaliones
Edit:
Kind Regards
Manuel
A WidgetGroupBox is more or less a WidgetVBox that draws a border around itself. you can modify how that border looks by modifying the png files in data/core/gui or if you don't want a border at all - just use WidgetVBox
It is a visual element (like border) of WidgetGroupBox to disable this visual use the following method WidgetGroupBox::setBackground(0). Or you can add skin layout for border, please, the following documentation:
Programming/ GUI/Skin Layout
Thanks, I didn't realized that, I switched now to a WidgetVBox.
Thanks, but WidgetGroupBox::setBackground(0) has no effect:
 Gui gui;
 gui = engine.getGui();
 WidgetGroupBox testBox;
 testBox = new WidgetGroupBox(gui);
 testBox.setWidth(200);
 testBox.setHeight(200);
 testBox.setBackground(0);
 gui.addChild(testBox, GUI_ALIGN_OVERLAP);
But I now understand the border and how to change the png for it, thanks a lot! (and sorry, I totally over read this documentation part)
