cor Posted January 14, 2012 Share Posted January 14, 2012 Hi I made a new class which I want to use inside a script. I created a new dll with this new class included. According the documentation a have to register the new class inside the main function. The problem is that I can not compile the main application because it uses nVidia files which I do not have (using 3DSurround). Can I register the class using functions inside the dll? Link to comment
ulf.schroeter Posted January 14, 2012 Share Posted January 14, 2012 Try creating Unigine plug-in dll. Have a look into existing Unigine plug-ins (e.g <unigine-sdk>\source\plugins\Network) for an example. Script exposure code example can be found in e.g. NetworkInterpreter.h/.cpp Link to comment
cor Posted January 14, 2012 Author Share Posted January 14, 2012 The problem is that it is a subclass of Player. I want to create a PlayerPilot class. And the Node class need to be aware of it too (defining a PLAYER_PILOT in the enumeration list of the Node class). Can this be done in a plug-in too? Link to comment
ulf.schroeter Posted January 14, 2012 Share Posted January 14, 2012 The problem is that it is a subclass of Player. I want to create a PlayerPilot class. And the Node class need to be aware of it too (defining a PLAYER_PILOT in the enumeration list of the Node class). Can this be done in a plug-in too? Don't think so, this will require modification of UNIGINE source code and rebuild of engine dll Link to comment
manguste Posted February 7, 2012 Share Posted February 7, 2012 Yes, any modifications of the source code require rebuilding of the engine dll. Extending the enumeration list of the Node class is just the case. Good news is that all Apps, including 3DSurround, have became plugins. So now you can customize the main app as you like. To load a plugin library, you just need to specify extern_plugin option on the start-up: main_x86d -extern_plugin App3DSurround Link to comment
