carl.sutton Posted November 21, 2011 Share Posted November 21, 2011 Hello. I have an object and I set its material base_transform parameter to its only surface like so; object.setMaterialParameter("base_transform", vec4(2,2,0,0), 0); This works and I get a repetition of my texture over my object. The problem lies in when I now set my material to a buffer as in the one found in editor_materials_buffer.h. When I hit the following code... // copy parameters forloop(int i = 0; material.getNumParameters()) { int type = material.getParameterType(i); string name = material.getParameterName(i); if(type == MATERIAL_PARAMETER_COLOR) parameters.append(name,material.getParameter(i)); else if(type == MATERIAL_PARAMETER_SLIDER) parameters.append(name,material.getParameterSlider(i)); else if(type == MATERIAL_PARAMETER_EXPRESSION) { parameters.append(name,material.getParameterExpression(i)); log.message("%s: %s\n", name, material.getParameterExpression(i)); //log message added for example } } ...I get the following in my log file: 16:03:05 base_transform: 16:03:05 detail_transform: vec4(1.0f,1.0f,0.0f,0.0f) Somewhere in the works through setting my base_transform manually, the expression data has been lost and I can't see where it would be going wrong my side. Any ideas? (Note I'm on SDK 2011-11-11) Link to comment
ulf.schroeter Posted November 21, 2011 Share Posted November 21, 2011 Do you initialize material variable via object.getMaterial(0) just before data access ? If so you could try object.getMaterialInherit(0) alternatively, as your base transform modification creates an inherited material instance for the surface Link to comment
carl.sutton Posted November 22, 2011 Author Share Posted November 22, 2011 I assumed getMaterialInherit would provide the parent material data and getMaterial was recieving the instanced data? How does this explain how parameters of type MATERIAL_PARAMETER_SLIDER and MATERIAL_PARAMETER_COLOR will work with my current approach of using getMaterial? Well for now I'll have a play with getMaterialInherit and see what happens. Link to comment
carl.sutton Posted November 22, 2011 Author Share Posted November 22, 2011 I have come to the conclusion that the problem was with me using Object::setMaterialParameter to set my expression. Even though my expression is a string representing a vec4, it is not the same as the vec4 value parameter in the function Object::setMaterialParameter. As object doesn't define a function for setParameterExpression as the material Class does I just assumed setMaterialParamter would set a parameter expression. I think I'll be able to fix this now. Thanks Link to comment
