Editor API
UnigineEditor public API
This class is used to represent a standard asset dialog of the UnigineEditor that can be used for opening and saving assets. More...
Classes | |
| struct | SelectedAsset |
| Structure representing an asset selected in the dialog. More... | |
Public Types | |
| enum | DialogMode { DialogMode::Modal, DialogMode::Modeless } |
| Dialog mode. More... | |
Static Public Member Functions | |
| static void | browseAsset (Unigine::CallbackBase1< const SelectedAsset & > *callback, const char *window_title=nullptr, const char *filter=nullptr, const char *hint_asset_path=nullptr, DialogMode mode=DialogMode::Modal) |
| Opens a dialog enabling the user to select a single asset. When the dialog opens, the specified default path and file filter shall be set displaying the corresponding elements. On selecting an asset and confirming selection by clicking OK, the specified callback function is executed. More... | |
| static void | browseAssetList (Unigine::CallbackBase1< const Unigine::Vector< SelectedAsset > & > *callback, const char *window_title=nullptr, const char *filter=nullptr, const char *hint_asset_path=nullptr, DialogMode mode=DialogMode::Modal) |
| Opens a dialog enabling the user to select multiple assets. When the dialog opens, the specified default path and file filter shall be set displaying the corresponding elements. On selecting assets and confirming selection by clicking OK, the specified callback function is executed. More... | |
| static void | saveAsset (Unigine::CallbackBase1< const char * > *callback, const char *window_title=nullptr, const char *filter=nullptr, const char *dest_path=nullptr, DialogMode mode=DialogMode::Modal) |
| Opens a dialog enabling the user to save an asset to the selected path. When the dialog opens, the specified default path and file filter shall be set displaying the corresponding elements. On selecting assets and confirming selection by clicking OK, the specified callback function is executed. More... | |
strong |
Dialog mode.
static |
| callback | Callback function to be fired on selecting an asset and clicking OK. The signature of the callback function is as follows: void (const SelectedAsset &) |
| window_title | Title of the dialog window. If not specified, the default title is 'Select Asset'. |
| filter | Filter, which is used to display files of required types only. List of file extensions with leading dots and without additional separators, for example: .mesh.prop. If the filter is empty, the dialog displays assets of all types. |
| hint_asset_path | Path to an asset to be selected by default when the dialog opens. |
| mode | Dialog mode to be set (see DialogMode). |
static |
| callback | Callback function to be fired on selecting assets and clicking OK. The signature of the callback function is as follows: void (const Unigine::Vector<SelectedAsset> &) |
static |
| callback | Callback function to be fired on selecting an asset and clicking OK. The signature of the callback function is as follows: void (const char *) |
| window_title | Title of the dialog window. If not specified, the default title is 'Save Asset'. |
| dest_path | Destination path to be set by default, when the dialog opens. |
