Editor API
UnigineEditor public API
UnigineEditor::MountPointParameters Class Reference
This class is used to manage parameters of mount points, such as access, path, filters. Mount points are used to extend the Engine's file system. Mount point is a sort of a symlink enabling you to extend the virtual file system of your project by adding any external folders and packages to the "data" directory. More...
#include <UnigineAssetManager.h>
Inherits APIInterface.
Public Types
enum  ACCESS { ACCESS_READONLY = 0, ACCESS_READWRITE }
 Access mode. More...
Public Member Functions
void setAccess (MountPointParameters::ACCESS access)
 Sets a new access mode for the mount point. More...
MountPointParameters::ACCESS getAccess () const
 Returns the current access mode of the mount point. More...
void setAbsolutePath (const char *path)
 Sets a new absolute path to the mounted folder/package. More...
const char * getAbsolutePath () const
 Returns the absolute path to the mounted folder/package. More...
void addExclusiveFilter (const char *exclusive_filter)
 Adds a new item to the list of exclusive filters (whitelist) to be used for files as a list of wildcards (e.g., "*.jpg", "some_folder_*"). This list is used to selectively add files of certain types or contents of folders with certain names. More...
Unigine::Vector< Unigine::String > getExclusiveFilters () const
 Returns the whole list of currently used exclusive filters (as a list of wildcards). This whitelist is used to selectively add files of certain types or contents of folders with certain names. More...
void addIgnoreFilter (const char *ignore_filter)
 Adds a new item to the list of ignore filters (blacklist) to be used for files as a list of wildcards (e.g., "*.jpg", "some_folder_*"). This list is used to selectively ignore files of certain types or contents of folders with certain names. More...
Unigine::Vector< Unigine::String > getIgnoreFilters () const
 Returns the whole list of currently used ignore filters (as a list of wildcards). This blacklist is used to selectively ignore files of certain types or contents of folders with certain names. More...
Static Public Member Functions
static Unigine::Ptr< MountPointParameterscreate ()
 Creates a new instance of the class. More...
Detailed Description
Member Enumeration Documentation
◆ ACCESS
Access mode.
Enumerator
ACCESS_READONLY
Read-only mode. The mount point is read-only, files contained in the mounted folder/package cannot be modified.
ACCESS_READWRITE
Read-write mode. The mount point access mode is read-write, files contained in the mounted folder/package can be modified.
Member Function Documentation
◆ addExclusiveFilter()
void UnigineEditor::MountPointParameters::addExclusiveFilter ( const char *  exclusive_filter)
Parameters
exclusive_filterNew exclusive filter item to be added (as a list of wildcards).
◆ addIgnoreFilter()
void UnigineEditor::MountPointParameters::addIgnoreFilter ( const char *  ignore_filter)
Parameters
ignore_filterNew ignore filter item to be added (as a list of wildcards).
◆ create()
static Unigine::Ptr<MountPointParameters> UnigineEditor::MountPointParameters::create ( )
static
◆ getAbsolutePath()
const char* UnigineEditor::MountPointParameters::getAbsolutePath ( ) const
◆ getAccess()
MountPointParameters::ACCESS UnigineEditor::MountPointParameters::getAccess ( ) const
◆ getExclusiveFilters()
Unigine::Vector<Unigine::String> UnigineEditor::MountPointParameters::getExclusiveFilters ( ) const
◆ getIgnoreFilters()
Unigine::Vector<Unigine::String> UnigineEditor::MountPointParameters::getIgnoreFilters ( ) const
◆ setAbsolutePath()
void UnigineEditor::MountPointParameters::setAbsolutePath ( const char *  path)
Parameters
pathNew absolute path to be set.
◆ setAccess()
void UnigineEditor::MountPointParameters::setAccess ( MountPointParameters::ACCESS  access)
Parameters
accessNew access mode to be set (see ACCESS).
