This class is used to represent a collection of values (boolean, integer, float, or string) that can represent a set of import parameters for an asset.
 More...
#include <UnigineCollection.h>
Inherits APIInterface.
| void | clear () |
|  | Clears the collection by removing all elements.  More...
| bool | isEmpty () const |
|  | Checks if the collection is empty or has any elements.  More...
| bool | hasValue (const char *value_name) const |
|  | Checks if the collection contains a value element with the specified name.  More...
| Unigine::Vector< Unigine::String > | getNames () const |
|  | Returns the list of names of all elements in the collection as a vector of strings.  More...
| bool | remove (const char *value_name) |
|  | Removes a value element with the specified name from the collection.  More...
| Collection::TYPE | getType (const char *value_name) const |
|  | Returns the type of a value element with the specified name (see TYPE).  More...
| void | setBool (const char *value_name, bool value) |
|  | Sets a new boolean value for the collection element with the specified name.  More...
| bool | getBool (const char *value_name, bool default_value=false) const |
|  | Returns the current boolean value of the collection element with the specified name.  More...
| void | setInt (const char *value_name, int value) |
|  | Sets a new integer value for the collection element with the specified name.  More...
| int | getInt (const char *value_name, int default_value=0) const |
|  | Returns the current integer value of the collection element with the specified name.  More...
| void | setFloat (const char *value_name, float value) |
|  | Sets a new float value for the collection element with the specified name.  More...
| float | getFloat (const char *value_name, float default_value=0) const |
|  | Returns the current float value of the collection element with the specified name.  More...
| void | setString (const char *value_name, const char *value) |
|  | Sets a new string value for the collection element with the specified name.  More...
| Unigine::String | getString (const char *value_name, const char *default_value=nullptr) const |
|  | Returns the current string value of the collection element with the specified name.  More...
◆ TYPE
Value type.
| Enumerator |
| TYPE_NONE | Boolean value.  |
| TYPE_BOOL | Boolean value type.  |
| TYPE_INT | Integer value type.  |
| TYPE_FLOAT | Float value type.  |
| TYPE_STRING | String value type.  |
◆ clear()
          | void UnigineEditor::Collection::clear | ( |  | ) |  |
◆ create()
          | static Unigine::Ptr<Collection> UnigineEditor::Collection::create | ( |  | ) |  |  | static |
Creates a new empty collection.
◆ getBool()
          | bool UnigineEditor::Collection::getBool | ( | const char * | value_name, |
          |  |  | bool | default_value = false |
          |  | ) |  | const |
- Parameters
    | value_name | Name of the collection element. |  | default_value | Default value to be returned in case the requested value does not exist or cannot be converted to the specified type. |
◆ getFloat()
          | float UnigineEditor::Collection::getFloat | ( | const char * | value_name, |
          |  |  | float | default_value = 0 |
          |  | ) |  | const |
- Parameters
◆ getInt()
          | int UnigineEditor::Collection::getInt | ( | const char * | value_name, |
          |  |  | int | default_value = 0 |
          |  | ) |  | const |
- Parameters
◆ getNames()
          | Unigine::Vector<Unigine::String> UnigineEditor::Collection::getNames | ( |  | ) | const |
◆ getString()
          | Unigine::String UnigineEditor::Collection::getString | ( | const char * | value_name, |
          |  |  | const char * | default_value = nullptr |
          |  | ) |  | const |
- Parameters
◆ getType()
          | Collection::TYPE UnigineEditor::Collection::getType | ( | const char * | value_name | ) | const |
- Parameters
◆ hasValue()
          | bool UnigineEditor::Collection::hasValue | ( | const char * | value_name | ) | const |
- Parameters
    | value_name | Name of the collection element to be checked. |
- Returns
- true if the collection contains an element with the specified name; otherwise, false.
◆ isEmpty()
          | bool UnigineEditor::Collection::isEmpty | ( |  | ) | const |
- Returns
- true if the collection is empty; otherwise, false.
◆ remove()
          | bool UnigineEditor::Collection::remove | ( | const char * | value_name | ) |  |
- Parameters
    | value_name | Name of the collection element to be removed. |
- Returns
- true if the element with the specified name is removed successfully; otherwise, false.
◆ setBool()
          | void UnigineEditor::Collection::setBool | ( | const char * | value_name, |
          |  |  | bool | value |
- Parameters
    | value_name | Name of the collection element to be updated. |  | value | New boolean value to be set. |
◆ setFloat()
          | void UnigineEditor::Collection::setFloat | ( | const char * | value_name, |
          |  |  | float | value |
- Parameters
    | value_name | Name of the collection element to be updated. |  | value | New float value to be set. |
◆ setInt()
          | void UnigineEditor::Collection::setInt | ( | const char * | value_name, |
          |  |  | int | value |
- Parameters
    | value_name | Name of the collection element to be updated. |  | value | New integer value to be set. |
◆ setString()
          | void UnigineEditor::Collection::setString | ( | const char * | value_name, |
          |  |  | const char * | value |
- Parameters
    | value_name | Name of the collection element to be updated. |  | value | New string value to be set. |
