Editor API
UnigineEditor public API
Editor::WindowManager Class Referencefinal
Window manager class. This class is used to manage tool windows in the Editor. More...
#include <WindowManager.h>
Inherits QObject.
Public Types
enum  AreaType {
  LAST_USED_AREA, NEW_FLOATING_AREA, ROOT_AREA_LEFT, ROOT_AREA_RIGHT,
  ROOT_AREA_TOP, ROOT_AREA_BOTTOM, NO_AREA
 ToolWindowManager area type. More...
enum  RefType {
  REF_ADD_TO, REF_LEFT_OF, REF_RIGHT_OF, REF_TOP_OF,
  REF_BOTTOM_OF
 Anchor type defining the way to layout tool windows. More...
Signals
void windowShown (QWidget *widget)
 This signal is emitted when a tool window is shown, with the tool window as an argument. More...
void beforeHide (QWidget *widget)
 This signal is emitted when before a tool window is hidden, with the tool window as an argument. More...
void windowHidden (QWidget *widget)
 This signal is emitted when a tool window is hidden, with the tool window as an argument. More...
void stateRestored ()
 This signal is emitted when the state of the Tool Window Manager is restored. More...
Static Public Member Functions
static WindowManager * instance ()
 Returns the instance of the WindowManager class. This method is used to subscribe to signals. More...
static void add (QWidget *widget, AreaType area=LAST_USED_AREA)
 Adds the specified tool window to the specified area of the main window. By default the tool window is added to the last used one. More...
static void add (QWidget *widget, RefType ref, QWidget *area)
 Adds the specified tool window to the specified window area according to the specified anchor type (RefType). More...
static void add (const Unigine::Vector< QWidget * > &widgets, AreaType area=LAST_USED_AREA)
 Adds the specified set of tool windows to the specified area of the main window. By default tool windows are added to the last used one. More...
static void add (const Unigine::Vector< QWidget * > &widgets, RefType ref, QWidget *area)
 Adds the specified set of tool windows to the specified area according to the specified anchor type (RefType). More...
static void remove (QWidget *widget)
 Removes the specified tool window. More...
static bool has (QWidget *widget)
 Checks if the specified tool window exists. More...
static void move (QWidget *widget, AreaType area=LAST_USED_AREA)
 Moves the specified tool window to the specified area of the main window. By default the tool window is moved to the last used one. More...
static void move (QWidget *widget, RefType ref, QWidget *area)
 Moves the specified tool window to the specified window area according to the specified anchor type (RefType). More...
static void move (const Unigine::Vector< QWidget * > &widgets, AreaType area=LAST_USED_AREA)
 Moves the specified set of tool windows to the specified area of the main window. By default tool windows are moved to the last used one. More...
static void move (const Unigine::Vector< QWidget * > &widgets, RefType ref, QWidget *area)
 Moves the specified set of tool windows to the specified area according to the specified anchor type (RefType). More...
static void resize (QWidget *widget, int width, int height)
 Resizes the specified tool window. More...
static void activate (QWidget *widget)
 Activates the specified tool window. More...
static void hide (QWidget *widget)
 Hides the specified tool window. More...
static bool isHidden (QWidget *widget)
 Checks whether the specified tool window is hidden. More...
static void show (QWidget *widget)
 Shows the specified tool window. More...
static bool isVisible (QWidget *widget)
 Checks whether the specified tool window is visible. More...
static QWidget * getArea (QWidget *child)
 Returns the area to which the specified tool window belongs. More...
static Unigine::Vector< QWidget * > allWindows ()
 Returns the list of all existing tool windows. More...
static QMenu * findMenu (const char *name)
 Searches for a submenu of the main menu bar with the specified name. More...
static QToolBar * findToolBar (const char *name)
 Searches for a toolbar with the specified name. More...
Detailed Description
Member Enumeration Documentation
◆ AreaType
Enumerator
LAST_USED_AREA
Last used area.
NEW_FLOATING_AREA
New floating area.
ROOT_AREA_LEFT
Left part of the root area.
ROOT_AREA_RIGHT
Right part of the root area.
ROOT_AREA_TOP
Upper part of the root area.
ROOT_AREA_BOTTOM
Lower part of the root area.
NO_AREA
No area.
◆ RefType
Enumerator
REF_ADD_TO
New tab occupying the whole area.
REF_LEFT_OF
Left anchor of the area.
REF_RIGHT_OF
Right anchor of the area.
REF_TOP_OF
Top anchor of the area.
REF_BOTTOM_OF
Bottom anchor of the area.
Member Function Documentation
◆ activate()
static void Editor::WindowManager::activate ( QWidget *  widget)
static
Parameters
widgetTool window to be activated.
◆ add() [1/4]
static void Editor::WindowManager::add ( QWidget *  widget,
AreaType  area = LAST_USED_AREA
static
Parameters
widgetTool window to be added.
areaMain window area to which the specified tool window is to be added.
To get a window area use getArea()
◆ add() [2/4]
RefType  ref,
QWidget *  area
static
Parameters
refAnchor type to define the layout relative to the specified area.
areaWindow area to which the specified tool window is to be added.
◆ add() [3/4]
static void Editor::WindowManager::add ( const Unigine::Vector< QWidget * > &  widgets,
static
Parameters
widgetsList of tool windows to be added.
areaMain window area to which the specified tool windows are to be added.
◆ add() [4/4]
RefType  ref,
QWidget *  area
static
Parameters
areaWindow area to which the specified tool windows are to be added.
◆ allWindows()
static Unigine::Vector<QWidget *> Editor::WindowManager::allWindows ( )
static
Returns
Vector containing all existing tool windows.
◆ beforeHide
void Editor::WindowManager::beforeHide ( QWidget *  widget)
signal
◆ findMenu()
static QMenu* Editor::WindowManager::findMenu ( const char *  name)
static
Parameters
nameName of the submenu to be found.
Returns
Menu with the specified name; otherwise nullptr.
◆ findToolBar()
static QToolBar* Editor::WindowManager::findToolBar ( const char *  name)
static
Parameters
nameName of the toolbar to be found.
Returns
Toolbar with the specified name; otherwise nullptr.
◆ getArea()
static QWidget* Editor::WindowManager::getArea ( QWidget *  child)
static
Parameters
childTool window for which the area is to be obtained.
Returns
The area to which the specified tool window belongs; otherwise nullptr.
◆ has()
static bool Editor::WindowManager::has ( QWidget *  widget)
static
Parameters
widgetTool window to be checked.
◆ hide()
static void Editor::WindowManager::hide ( QWidget *  widget)
static
Parameters
widgetTool window to be hidden.
◆ instance()
static WindowManager* Editor::WindowManager::instance ( )
static
Returns
WindowManager class instance.
Example:
,this , [this](QWidget *widget)
if (widget == this)
clear();
◆ isHidden()
static bool Editor::WindowManager::isHidden ( QWidget *  widget)
static
Parameters
◆ isVisible()
static bool Editor::WindowManager::isVisible ( QWidget *  widget)
static
Parameters
◆ move() [1/4]
static void Editor::WindowManager::move ( QWidget *  widget,
static
Parameters
widgetTool window to be moved.
areaMain window area to which the specified tool window is to be moved.
◆ move() [2/4]
RefType  ref,
QWidget *  area
static
Parameters
areaWindow area to which the specified tool window is to be moved.
◆ move() [3/4]
static void Editor::WindowManager::move ( const Unigine::Vector< QWidget * > &  widgets,
static
Parameters
widgetsList of tool windows to be moved.
areaMain window area to which the specified tool windows are to be moved.
◆ move() [4/4]
RefType  ref,
QWidget *  area
static
Parameters
areaWindow area to which the specified tool windows are to be moved.
◆ remove()
static void Editor::WindowManager::remove ( QWidget *  widget)
static
Parameters
widgetTool window to be removed.
◆ resize()
static void Editor::WindowManager::resize ( QWidget *  widget,
int  width,
int  height
static
Parameters
widgetTool window to be resized.
widthNew tool window width, in pixels.
heightNew tool window height, in pixels.
◆ show()
static void Editor::WindowManager::show ( QWidget *  widget)
static
Parameters
widgetTool window to be shown.
◆ stateRestored
void Editor::WindowManager::stateRestored ( )
signal
◆ windowHidden
void Editor::WindowManager::windowHidden ( QWidget *  widget)
signal
◆ windowShown
void Editor::WindowManager::windowShown ( QWidget *  widget)
signal
