Editor API
UnigineEditor public API
Editor::AssetManager Class Referencefinal
This class is used to manage assets in the Editor. You can check if an asset with the specified GUID exists, get its file path, or subscribe for signals to perform certain actions when an asset is added, moved, updated, or deleted. More...
#include <AssetManager.h>
Inherits QObject.
Signals
void added (const Unigine::UGUID &guid)
 This signal is emitted when a new asset is added, with the asset's GUID as an argument. More...
void removed (const Unigine::UGUID &guid)
 This signal is emitted when an asset is deleted, with the asset's GUID as an argument. More...
void changed (const Unigine::UGUID &guid)
 This signal is emitted when an asset is modified, with the asset's GUID as an argument. More...
void moved (const Unigine::UGUID &guid)
 This signal is emitted when an asset is moved to another location, with the asset's GUID as an argument. More...
Static Public Member Functions
static AssetManagerinstance ()
 Returns the instance of the AssetManager class. This method is used to subscribe to signals. More...
static bool hasAsset (const Unigine::UGUID &guid)
 Returns a value indicating whether an asset with the specified GUID exists. More...
static bool hasAsset (const char *s_filepath)
 Returns a value indicating whether an asset with the specified file path exists. More...
static Unigine::Vector< Unigine::UGUID > assets ()
 Returns the list of GUIDs for all existing assets. More...
static Unigine::Vector< Unigine::UGUID > assets (const char *dirpath)
 Returns the list of GUIDs for all assets existing in the specified directory. More...
static Unigine::String assetFilePath (const Unigine::UGUID &guid)
 Returns the path to the asset file by its GUID. More...
Detailed Description
Member Function Documentation
◆ added
void Editor::AssetManager::added ( const Unigine::UGUID &  guid)
signal
◆ assetFilePath()
static Unigine::String Editor::AssetManager::assetFilePath ( const Unigine::UGUID &  guid)
static
Parameters
guidGUID of the asset to find the path for.
◆ assets() [1/2]
static Unigine::Vector<Unigine::UGUID> Editor::AssetManager::assets ( )
static
◆ assets() [2/2]
static Unigine::Vector<Unigine::UGUID> Editor::AssetManager::assets ( const char *  dirpath)
static
Parameters
dirpathPath to a directory containing assets.
◆ changed
void Editor::AssetManager::changed ( const Unigine::UGUID &  guid)
signal
◆ hasAsset() [1/2]
static bool Editor::AssetManager::hasAsset ( const Unigine::UGUID &  guid)
static
Parameters
guidGUID of the asset to be checked.
◆ hasAsset() [2/2]
static bool Editor::AssetManager::hasAsset ( const char *  s_filepath)
static
Parameters
s_filepathPath of the asset to be checked.
◆ instance()
static AssetManager* Editor::AssetManager::instance ( )
static
Returns
AssetManager class instance.
Example:
, this, &SomeClass::asset_changed);
◆ moved
void Editor::AssetManager::moved ( const Unigine::UGUID &  guid)
signal
◆ removed
void Editor::AssetManager::removed ( const Unigine::UGUID &  guid)
signal
