Oil Platform Demo
You should upgrade to- Engineering / Sim
SDK edition to use it.
Offshore oil rig demo showcases global water (ObjectWaterGlobal) capabilities.
Features#
- Beaufort scale 0-12
- Vessels and buoys floating on the water surface
- Interactive helicopter mode
- Hardware tessellation for water geometry
- Multiple point lights with batching
SDK Path: <SDK_INSTALLATION>demos\oil_platform_2.18.1
Accessing Demo Source Code#
- Find the Oil Platform Demo demo in the Demos section and click Install (if you haven't installed it yet).
- After successful installation the demo will appear in the Installed section, and you can click Copy as Project to create a project based on this demo.
- In the Create New Project window, that opens, enter the name for your new project in the corresponding field and click Create New Project.
- Now you can click Open Code IDE to check and modify source code in your default IDE, or click Open Editor to open the project in the UnigineEditor.
