Weapon Clipping
In first-person games, weapon models can clip through walls or geometry when the camera gets too close. This sample solves the problem by rendering the weapon separately into a texture and overlaying it on top of the main camera view.
The setup uses two cameras with identical transforms to keep their views aligned. Viewport masks for cameras are set via UnigineEditor: the main camera renders everything except the weapon, while the secondary (weapon) camera renders only the weapon. The weapon view is captured into a texture using Viewport.RenderTexture2D().
Each frame, this texture is overlaid onto the screen using Render.RenderScreenMaterial(), compositing the weapon on top of the environment. The component handles screen resizing, maintains isolated render states, and offers optional settings like skipping shadows in the weapon rendering pass.
This approach keeps the weapon always visible, even when the camera is close to walls, without interfering with the main rendering pipeline
SDK Path: <SDK_INSTALLATION>data/csharp_component_samples/render/weapon_clipping
Accessing Demo Source Code#
  1. Find the C# Component Samples demo in the Demos section and click Install (if you haven't installed it yet).
  2. After successful installation the demo will appear in the Installed section, and you can click Copy as Project to create a project based on this demo.
  3. In the Create New Project window, that opens, enter the name for your new project in the corresponding field and click Create New Project.
  4. Now you can click Open Code IDE to check and modify source code in your default IDE, or click Open Editor to open the project in the UnigineEditor.
Last update: 10.07.2025
