Water Global
The Water Global samples demonstrates how to control Global Water via API:
SDK Path: <SDK_INSTALLATION>
Accessing Demo Source Code#
- Find the C# Component Samples demo in the Demos section and click Install (if you haven't installed it yet).
- After successful installation the demo will appear in the Installed section, and you can click Copy as Project to create a project based on this demo.
- In the Create New Project window, that opens, enter the name for your new project in the corresponding field and click Create New Project.
- Now you can click Open Code IDE to check and modify source code in your default IDE, or click Open Editor to open the project in the UnigineEditor.
Была ли эта статья полезной?
