API Samples
Transform Space Node
This node is used to transform a POSITION vector from one space (Camera World, Object, View, Absolute World) to another space. Suppose you have a position coordinate in Object space and you want to use it where the same position coordinate is required but in a different space - View, for example. You can use this node to switch to the required space.
Double-click somewhere within a node to change initial (From) and target (To) space.
Last update: 13.12.2024
