Unigine::TextureRamp Class
Header: #include <UnigineTextures.h>
Interface for handling ramp textures. This class lets the user store 2d curves in a form of a texture (convert vectors to raster data).
Ramp textures can be used for color variation in the particles_base material of Particle Systems or in other custom materials.
You can set up to 4 channels for the ramp texture.
TextureRamp Class
Members
Ptr<Texture> getTexture() const#
Returns the current new texture and updates hashes for curves, if required. Returns a pointer to the texture or null if the texture was not created.
Return value
Current new texture.
void setNumChannels ( int channels ) #
Sets a new number of channels for the texture.
Arguments
  • int channels - The number of texture channels.
int getNumChannels() const#
Returns the current number of channels for the texture.
Return value
Current number of texture channels.
void setResolution ( int resolution ) #
Sets a new width resolution for the texture.
Arguments
  • int resolution - The texture width resolution.
int getResolution() const#
Returns the current width resolution for the texture.
Return value
Current texture width resolution.
void setFlags ( int flags ) #
Sets a new texture flags.
Arguments
  • int flags - The texture flags.
int getFlags() const#
Returns the current texture flags.
Return value
Current texture flags.
bool isDefaultAll() const#
Returns the current value indicating if the values of all curve channels are the default ones which were previously set via setDefaultCurve.
Return value
true if the values of all curve channels are the default ones which were previously set via setDefaultCurve; otherwise false.
Event<> getEventChanged() const#
event triggered on changing the ramp texture. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
The event handler signature is as follows: myhandler()
Usage Example
// implement the Changed event handler
void changed_event_handler()
	Log::message("\Handling Changed event\n");
EventConnections changed_event_connections;
publisher->getEventChanged().connect(changed_event_connections, changed_event_handler);
publisher->getEventChanged().connect(changed_event_connections, []() {
		Log::message("\Handling Changed event (lambda).\n");
changed_event_connections.disconnectAll();
EventConnection changed_event_connection;
// subscribe to the Changed event with a handler function keeping the connection
publisher->getEventChanged().connect(changed_event_connection, changed_event_handler);
changed_event_connection.setEnabled(false);
changed_event_connection.setEnabled(true);
// remove subscription to the Changed event via the connection
changed_event_connection.disconnect();
// Class handling the event
class SomeClass
	// A Changed event handler implemented as a class member
	void event_handler()
publisher->getEventChanged().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
EventConnectionId changed_handler_id;
// subscribe to the Changed event with a lambda handler function and keeping connection ID
changed_handler_id = publisher->getEventChanged().connect(e_connections, []() {
publisher->getEventChanged().disconnect(changed_handler_id);
//   5. Ignoring all Changed events when necessary
publisher->getEventChanged().setEnabled(false);
publisher->getEventChanged().setEnabled(true);
Return value
Event reference.
static TextureRampPtr create ( int num_channels, int resolution, int flags ) #
Sets resolution, number of channels and texture flags for this TextureRamp instance. The pointer to the ramp texture is set to null and curves are marked for an update.
Arguments
  • int num_channels - Number of texture channels.
  • int resolution - Width resolution of the ramp texture.
  • int flags - Texture flags.
static TextureRampPtr create ( const Ptr<TextureRamp> & texture_ramp ) #
Ramp texture constructor. Creates a new ramp texture by copying a given source ramp texture.
Arguments
  • const Ptr<TextureRamp> & texture_ramp - Pointer to a new ramp texture.
TextureRamp ( ) #
void releaseTexture ( ) #
Deletes the texture and its pointer.
void copy ( const Ptr<TextureRamp> & src_texture_ramp ) #
Copies the data of a source ramp texture to the texture.
Arguments
  • const Ptr<TextureRamp> & src_texture_ramp - Source ramp texture.
Ptr<TextureRamp> clone ( ) const#
Duplicates the ramp texture and returns a pointer to the copy.
Ptr<Curve2d> getCurve ( int channel ) const#
Returns a pointer to the Curve2d for the specified channel.
Arguments
  • int channel - Required channel.
Return value
Pointer to a Curve2d object.
void setDefaultCurve ( const Ptr<Curve2d> & default_curve ) #
Resets a curve to a default one.
Arguments
  • const Ptr<Curve2d> & default_curve - A curve to be used as the default one.
void setDefaultCurve ( int channel, const Ptr<Curve2d> & default_curve ) #
Resets a curve for the given channel to a default one.
Arguments
  • int channel - R, G, B, or A channel set by the corresponding value from 0 to 3.
bool isDefault ( int channel ) const#
Returns a value indicating if the value of the given curve channel is the default one which was previously set via setDefaultCurve.
Arguments
Return value
true if the curve value is the default one set via setDefaultCurve, otherwise false.
void save ( const Ptr<Xml> & xml ) #
Saves the ramp texture data to the given Xml node.
Arguments
  • const Ptr<Xml> & xml - Target Xml node.
void save ( const Ptr<Json> & json ) const#
Saves the ramp texture data to the given Json class instance.
Arguments
  • const Ptr<Json> & json - Target son class instance.
void load ( const Ptr<Xml> & xml ) #
Loads the ramp texture data from the given Xml node.
Arguments
  • const Ptr<Xml> & xml - Source Xml node containing ramp texture data.
void load ( const Ptr<Json> & json ) #
Loads the ramp texture data from the given Json class instance.
Arguments
  • const Ptr<Json> & json - Source Json class instance containing ramp texture data.
void saveState ( const Ptr<Stream> & stream ) const#
Saves the state of the ramp texture into a binary stream.
Example using saveState() and restoreState() methods:
// initialize a node and set its state
// save state
BlobPtr blob_state = Blob::create();
ramp->saveState(blob_state);
// change state
// restore state
blob_state->seekSet(0);				// returning the carriage to the start of the blob
ramp->restoreState(blob_state);
Arguments
  • const Ptr<Stream> & stream - The stream to save the ramp texture state data.
void restoreState ( const Ptr<Stream> & stream ) const#
Restores the state of the ramp texture from the binary stream.
// save state
// change state
// restore state
Arguments
  • const Ptr<Stream> & stream - The stream that stores the ramp texture state data.
Last update: 27.03.2024
