Unigine::Console Class
Header: #include <UnigineConsole.h>
Controls console-related parameters.
Onscreen Console Overlay#
By default the console overlay is disabled. To make it output console messages to the application screen it should be enabled. You can adjust the overlay’s behavior and appearance as well as specify the messages that will be printed exclusively to the onscreen overlay and will not be written to the console.
Onscreen Overlay with custom parameters and colored text
You can customize the console font by using the setFontSize(), setMessageColor(), setWarningColor(), and setErrorColor() methods. See the following example:
AppWorldLogic.cpp (C++)
#include "AppWorldLogic.h"
int AppWorldLogic::init()
	// enable the onscreen overlay
	Console::setOnscreen(true);
	// increase the size of the console's font
	Console::setFontSize(20);
	// change the color for different types of messages
	Console::setMessageColor(Unigine::Math::vec4_green);
	Console::setWarningColor(Unigine::Math::vec4_red);
	Console::setErrorColor(Unigine::Math::vec4_blue);
	// send messages to the console
	Log::message("Message!\n");
	Log::warning("Warning!\n");
	Log::error("Error!\n");
Adding Console Command with Several Arguments#
The Console class can be used to create custom user console commands with a different number of arguments. This section provides an example of how to create a custom console command with several arguments.
Prior Knowledge
It is supposed that you have already created an empty C++ project by using UNIGINE SDK Browser.
In the example below, we perform the following actions:
  • Define and implement AppWorldLogic instance methods for console commands.
  • Get the console instance (which has a singleton implementation) and add a new command.
1. Adding Instance Methods
In this example, we define three methods in the AppWorldLogic.h header file — one as a callback for a console command and another two methods for actions depending on the number of arguments:
	AppWorldLogic();
	// choose the method to run on the console command call
	void choose_command(int argc, char** argv);
	// perform an action if there are no arguments
	void action_no_args();
	// perform another action if an argument was passed
	void action_one_arg(const char* s);
  • choose_command() selects the appropriate method.
  • action_no_args() is called if there are no console arguments.
  • action_one_arg() is called if an argument was passed.
In the AppWorldLogic.cpp file implement recently defined methods:
// check the number of arguments and call the corresponding method
void AppWorldLogic::choose_command(int argc, char** argv) {
	for (int i = 0; i < argc; i++) {
		Log::message("arg[%d]: %s\n", i, argv[i]);
	// note: the first element of argv is the name of console command
	if (argc == 1) {
		action_no_args();
	else if (argc == 2) {
		action_one_arg(argv[1]);
	// for more arguments:
	//else if (...) {
	//	// etc
// write the message into console, if there are no arguments
void AppWorldLogic::action_no_args() {
	Log::message("first action! no arguments!\n");
// write the message into console, if an argument was passed
void AppWorldLogic::action_one_arg(const char* s) {
	Log::message("second action! the argument is:%s \n", s);
Arguments argc and argv are used to get the arguments count and arguments vector.
The first element of argv always keeps the name of a console command. Thus, argc is always >= 1. To get the first passed argument, you should use argv[1].
2. Adding Custom Console Command
Add custom command to the AppWorldLogic.cpp file by using addCommand() function. By adding this code into AppWorldLogic::init() function, the engine adds a new console command on AppWorldLogic class instance initialization.
#include <UnigineCallback.h>
	// get the existing singleton Console instance and add a command
	Console::addCommand(
		"console_action",
		"Performs custom console action",
		MakeCallback(this, &AppWorldLogic::choose_command)
3. Running Sample
After building the project, run it and open the console. Write recently created command to see the result:
Output
#if you write "console_action"
arg[0]: console_action
#if you write "console_action arg"
arg[0]: console action
arg[1]: arg
second action! the argument is:arg
To remove the added console command, use removeCommand() method.
  • C++ API sample located in the folder <UnigineSDK>/source/samples/Api/Systems/Console
  • C# API sample located in the folder <UnigineSDK>/source/csharp/samples/Api/Systems/Console
  • HowTo video on Printing User Messages to Console with C#
Console Class
Перечисления (Enums)
LEVEL#
ИмяОписание
LEVEL_NORMAL = 0An ordinary message.
LEVEL_WARNING = 1A warning.
LEVEL_ERROR = 2An error message.
Members
void setLock ( int lock ) #
Sets a new value showing if the console is disabled.
Arguments
  • int lock - The value set to 1 (or any positive value) means that the console is disabled; the value of 0 corresponds to the enabled (unlocked) console.
int getLock() const#
Returns the current value showing if the console is disabled.
Return value
Current value set to 1 (or any positive value) means that the console is disabled; the value of 0 corresponds to the enabled (unlocked) console.
int getNumCommands() const#
Returns the current number of all available console commands, including the custom ones.
Return value
Current number of available console commands.
int getNumVariables() const#
Returns the current number of all available console variables.
Return value
Current number of available console variables.
void setActive ( bool active ) #
Sets a new value indicating if the console is opened or closed.
Arguments
  • bool active - Set true to enable the active (opened) state of the console; false - to disable it.
bool isActive() const#
Returns the current value indicating if the console is opened or closed.
Return value
true if the active (opened) state of the console is enabled; otherwise false.
const char * getLastError() const#
Returns the current last error message printed to the console.
Return value
Current last error message printed to the console.
const char * getLastWarning() const#
Returns the current last warning message printed to the console.
Return value
Current last warning message printed to the console.
const char * getLastMessage() const#
Returns the current last message printed to the console.
Return value
Current last message printed to the console.
void setOnscreenTime ( float time ) #
Sets a new time during which the text is displayed on the screen.
Arguments
  • float time - The time during which the text is displayed on the screen, in seconds.
float getOnscreenTime() const#
Returns the current time during which the text is displayed on the screen.
Return value
Current time during which the text is displayed on the screen, in seconds.
void setOnscreenHeight ( int height ) #
Sets a new height for the onscreen overlay.
Arguments
  • int height - The height of the onscreen overlay in percentage of the window height.
int getOnscreenHeight() const#
Returns the current height for the onscreen overlay.
Return value
Current height of the onscreen overlay in percentage of the window height.
void setOnscreenFontSize ( int size ) #
Sets a new size of the onscreen overlay font.
Arguments
  • int size - The size of the onscreen overlay font.
int getOnscreenFontSize() const#
Returns the current size of the onscreen overlay font.
Return value
Current size of the onscreen overlay font.
void setOnscreen ( bool onscreen ) #
Sets a new value indicating if the onscreen overlay is shown or hidden.
Arguments
  • bool onscreen - Set true to enable display of the onscreen overlay; false - to disable it.
bool isOnscreen() const#
Returns the current value indicating if the onscreen overlay is shown or hidden.
Return value
true if display of the onscreen overlay; otherwise false.
void setFontSize ( int size ) #
Sets a new current font size used for console messages.
Arguments
  • int size - The current font size used for console messages.
int getFontSize() const#
Returns the current current font size used for console messages.
Return value
Current current font size used for console messages.
void setWrapping ( bool wrapping ) #
Sets a new value indicating if the text wrapping is enabled for the console.
Arguments
  • bool wrapping - Set true to enable text wrapping for the console; false - to disable it.
bool isWrapping() const#
Returns the current value indicating if the text wrapping is enabled for the console.
Return value
true if text wrapping for the console is enabled; otherwise false.
void setHeight ( int height ) #
Sets a new console height in percentage of the window height.
Arguments
  • int height - The console height in percentage of the window height.
int getHeight() const#
Returns the current console height in percentage of the window height.
Return value
Current console height in percentage of the window height.
void setLimit ( int limit ) #
Sets a new maximum number of messages the console can output. the default value is 16384.
Arguments
  • int limit - The maximum number of messages the console can output. the default value is 16384.
int getLimit() const#
Returns the current maximum number of messages the console can output. the default value is 16384.
Return value
Current maximum number of messages the console can output. the default value is 16384.
void setPrompt ( const char * prompt ) #
Sets a new console prompt.
Arguments
  • const char * prompt - The console prompt text.
const char * getPrompt() const#
Returns the current console prompt.
Return value
Current console prompt text.
void setTextColor ( const Math::vec4& color ) #
Sets a new common font color for the console.
Arguments
  • const Math::vec4& color - The four-component vector specifying the color in the RGBA format.
Math::vec4 getTextColor() const#
Returns the current common font color for the console.
Return value
Current four-component vector specifying the color in the RGBA format.
void setErrorColor ( const Math::vec4& color ) #
Sets a new color for error messages in the console.
Arguments
Math::vec4 getErrorColor() const#
Returns the current color for error messages in the console.
Return value
void setWarningColor ( const Math::vec4& color ) #
Sets a new color for warning messages in the console.
Arguments
Math::vec4 getWarningColor() const#
Returns the current color for warning messages in the console.
Return value
void setMessageColor ( const Math::vec4& color ) #
Sets a new color for ordinary messages in the console.
Arguments
Math::vec4 getMessageColor() const#
Returns the current color for ordinary messages in the console.
Return value
void setBackgroundColor ( const Math::vec4& color ) #
Sets a new background color for the console.
Arguments
Math::vec4 getBackgroundColor() const#
Returns the current background color for the console.
Return value
Event<const char *, Console::LEVEL> getEventOutput() const#
event triggered when a text is output to the console. You can subscribe to events via connect()  and unsubscribe via disconnect(). You can also use EventConnection  and EventConnections  classes for convenience (see examples below).
Usage Example
// implement the Output event handler
void output_event_handler(const char * text,  Console::LEVEL level)
	switch (level) {
	case Console::LEVEL_NORMAL:
		// logic for ordinary messages
	case Console::LEVEL_WARNING:
		// logic for warnings
	case Console::LEVEL_ERROR:
		// logic for error messages
EventConnections output_event_connections;
// link to this instance when subscribing for an event (subscription for various events can be linked)
Console::getEventOutput().connect(output_event_connections, output_event_handler);
Console::getEventOutput().connect(output_event_connections, [](const char * text,  Console::LEVEL level) {
		Log::message("\Handling Output event (lambda).\n");
output_event_connections.disconnectAll();
EventConnection output_event_connection;
// subscribe for the Output event with a handler function keeping the connection
Console::getEventOutput().connect(output_event_connection, output_event_handler);
output_event_connection.setEnabled(false);
output_event_connection.setEnabled(true);
// remove subscription for the Output event via the connection
output_event_connection.disconnect();
// Class handling the event
class SomeClass
	// A Output event handler implemented as a class member
	void event_handler(const char * text,  Console::LEVEL level)
		Log::message("\Handling Output event\n");
Console::getEventOutput().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
//  4. You can subscribe and unsubscribe via the handler function directly
Console::getEventOutput().connect(output_event_handler);
// remove subscription for the Output event later by the handler function
Console::getEventOutput().disconnect(output_event_handler);
//   5. Subscribe to an event saving an ID and unsubscribe later by this ID
// define a connection ID to be used to unsubscribe later
EventConnectionId output_handler_id;
// subscribe for the Output event with a lambda handler function and keeping connection ID
output_handler_id = Console::getEventOutput().connect([](const char * text,  Console::LEVEL level) {
Console::getEventOutput().disconnect(output_handler_id);
//   6. Ignoring all Output events when necessary
Console::getEventOutput().setEnabled(false);
Console::getEventOutput().setEnabled(true);
The event handler signature is as follows: myhandler(const char * text, Console::LEVEL level)
Usage Example
publisher->getEventOutput().connect(output_event_connections, output_event_handler);
publisher->getEventOutput().connect(output_event_connections, [](const char * text,  Console::LEVEL level) {
// subscribe to the Output event with a handler function keeping the connection
publisher->getEventOutput().connect(output_event_connection, output_event_handler);
// remove subscription to the Output event via the connection
class SomeClass
publisher->getEventOutput().connect(sc->e_connections, sc, &SomeClass::event_handler);
delete sc;
// subscribe to the Output event with a lambda handler function and keeping connection ID
output_handler_id = publisher->getEventOutput().connect(e_connections, [](const char * text,  Console::LEVEL level) {
publisher->getEventOutput().disconnect(output_handler_id);
//   5. Ignoring all Output events when necessary
publisher->getEventOutput().setEnabled(false);
publisher->getEventOutput().setEnabled(true);
Return value
Event reference.
bool isCommand ( const char * name ) const#
Returns a value indicating if a command with a given name exists.
Arguments
  • const char * name - The command name.
Return value
true if the command with a given name exists; otherwise, false.
const char * getCommandDescription ( const char * name ) const#
Returns the description of the console command by its name. If the name isn't specified, an empty string will be returned.
Arguments
Return value
The command description if it exists; otherwise, an empty string.
const char * getCommandName ( int num ) const#
Returns the name of the console command by its number in the array of the existing commands.
Arguments
  • int num - The command number.
Return value
The command name if it is found in the array of the existing commands; otherwise, an empty string.
void setFloat ( const char * name, float value ) #
Sets a float value for a given variable.
Arguments
  • const char * name - The variable name.
  • float value - Float value of the variable.
float getFloat ( const char * name ) const#
Returns a float value of a given variable.
Arguments
Return value
float getFloatMax ( const char * name ) const#
Returns a maximum float value for a given variable.
Arguments
  • const char * name - Variable name.
Return value
Maximum float value of the variable.
float getFloatMin ( const char * name ) const#
Returns a minimum float value for a given variable.
Arguments
Return value
Minimum float value of the variable.
bool isFloat ( const char * name ) const#
Checks if the value set for the given console variable is of the float type.
Arguments
Return value
True if the variable value is float; otherwise, false.
void setInt ( const char * name, int value ) #
Sets an integer value for a given variable.
Arguments
  • const char * name - Name of the variable.
  • int value - Integer value of the variable.
int getInt ( const char * name ) const#
Returns an integer value of a given variable.
Arguments
Return value
int getIntMax ( const char * name ) const#
Returns a maximum integer value for a given variable.
Arguments
Return value
Maximum integer value of the variable.
int getIntMin ( const char * name ) const#
Returns a minimum integer value for a given variable.
Arguments
Return value
Minimum integer value of the variable.
bool isInt ( const char * name ) const#
Checks if the value of the given console variable is of the integer type.
Arguments
Return value
True if the variable value is int; otherwise, false.
bool isPalette ( const char * name ) const#
Checks for a palette with the specified name.
Arguments
  • const char * name - Palette name.
void setPalette ( const char * name, const Palette& value ) #
Sets a color palette by its name.
Arguments
  • const Palette& value - Palette to be set.
void setPalette ( const char * name, int index, float value ) #
Sets a value for the specified palette color by its index.
Arguments
  • int index - Palette color index.
  • float value - Value to be set for the color with the specified index.
void setPalette ( const char * name, const char * color, float value ) #
Sets a value for the specified palette color by the color name.
Arguments
  • const char * color - Palette color name.
  • float value - Value to be set for the color with the specified name.
Palette getPalette ( const char * name ) const#
Returns a color palette by its name.
Arguments
Return value
Palette with the specified name is it exists; otherwise nullptr.
void setString ( const char * name, const char * value ) #
Sets a string value for a given variable.
Arguments
  • const char * value - String value of the variable.
const char * getString ( const char * name ) const#
Returns the string value of a given variable.
Arguments
Return value
bool isString ( const char * name ) const#
Checks if the value of the given console variable is of the string type.
Arguments
Return value
True if the variable value is string; otherwise, false.
bool isVariable ( const char * name ) const#
Returns a value indicating if a variable with a given name exists.
Arguments
Return value
True if the variable exists; otherwise, false.
const char * getVariableDescription ( const char * name ) const#
Returns the description of the console variable by its name. If the name isn't specified, an empty string will be returned.
Arguments
Return value
The variable description if it exists; otherwise, an empty string.
const char * getVariableName ( int num ) const#
Returns the name of the console variable by its number in the array of the existing variables.
Arguments
  • int num - The variable number.
Return value
The variable name if it is found in the array of the existing variables; otherwise, an empty string.
void setVec2 ( const char * name, const Math::vec2 & value ) #
Sets a two component vector for the console variable.
Arguments
  • const Math::vec2 & value - Value of the variable.
Math::vec2 getVec2 ( const char * name ) const#
Returns the two component vector console variable.
Arguments
Return value
bool isVec2 ( const char * name ) const#
Returns a value indicating if the console variable is a two component vector.
Arguments
Return value
True if the variable is a two component vector; otherwise, false.
void setVec3 ( const char * name, const Math::vec3 & value ) #
Sets a three component vector for the console variable.
Arguments
  • const Math::vec3 & value - Value of the variable.
Math::vec3 getVec3 ( const char * name ) const#
Returns the three component vector console variable.
Arguments
Return value
bool isVec3 ( const char * name ) const#
Returns a value indicating if the console variable is a three component vector.
Arguments
Return value
True if the variable is a three component vector; otherwise, false.
void setVec4 ( const char * name, const Math::vec4 & value ) #
Sets a four component vector for the console variable.
Arguments
  • const Math::vec4 & value - Value of the variable.
Math::vec4 getVec4 ( const char * name ) const#
Returns the four component vector console variable.
Arguments
Return value
bool isVec4 ( const char * name ) const#
Returns a value indicating if the console variable is a four component vector.
Arguments
  • const char * name
Return value
int addCommand ( const char * name, const char * desc, CallbackBase * callback ) #
Adds a custom console command bound to a given callback function.
Arguments
  • const char * name - Name of the new console command.
  • const char * desc - Short description to be displayed in the console.
  • CallbackBase * callback - The callback pointer. The callback arguments must be (int argc, char** argv,...).
Return value
1 if the custom command is added successfully; otherwise, 0.
void flush ( ) #
Forces to execute all queued console commands.
bool removeCommand ( const char * name ) #
Removes a custom console command.
Arguments
  • const char * name - Name of the custom console command.
Return value
true if the custom command has been removed successfully; otherwise, 0.
void run ( const char * command ) #
Runs the specified console command.
Arguments
  • const char * command - A console command with arguments.
void write ( const char * text ) #
Writes the specified text to the console and displays it on the screen (onscreen overlay).
The onscreen overlay must be enabled for the text to be seen.
Arguments
  • const char * text - Text to output to the console.
void write ( const Math::vec4 & color, const char * text ) #
Arguments
  • const Math::vec4 & color - Four-component vector specifying the text color in the RGBA format.
void write ( Console::LEVEL level, const char * text ) #
Arguments
  • Console::LEVEL level - Type of the message.
static void getMessages ( Vector < String > & messages, int limit ) #
Gets the messages written to the console and the onscreen overlay.
Arguments
  • Vector < String > & messages - Vector to populate with messages.
  • int limit - Maximum number of messages to retrieve.
void getMessages ( Vector< String > & OUT_messages, Vector< int > & OUT_levels, int limit ) const#
Arguments
  • Vector< String > & OUT_messages - Vector to populate with messages.
  • Vector< int > & OUT_levels - Types of messages to retrieve.
static void getWarnings ( Vector < String > & messages, int limit ) #
Gets the warning messages written to the console and the onscreen overlay.
Arguments
void getErrors ( Vector < String > & messages, int limit ) #
Gets the error messages written to the console and the onscreen overlay.
Arguments
static void writeLine ( const char * text ) #
Writes the text followed by the line terminator to the console and the onscreen overlay.
Arguments
static void writeLine ( const Math::vec4 & color, const char * text ) #
Arguments
static void writeLine ( Console::LEVEL level, const char * text ) #
Arguments
static void onscreenWrite ( const char * text ) #
Writes the text to the onscreen overlay only.
Arguments
static void onscreenWrite ( const Math::vec4 color, const char * text ) #
Arguments
  • const Math::vec4 color - Four-component vector specifying the text color in the RGBA format.
static void onscreenWrite ( Console::LEVEL level, const char * text ) #
Arguments
static void onscreenWriteLine ( const char * text ) #
Writes the text only to the onscreen overlay followed by the line terminator.
The console overlay must be enabled for the text to be seen on the screen.
Arguments
static void onscreenWriteLine ( Math::vec4 & color, const char * text ) #
Arguments
  • Math::vec4 & color - Four-component vector specifying the text color in the RGBA format.
static void onscreenWriteLine ( Console::LEVEL level, const char * text ) #
Arguments
static void message ( const Unigine:: Math::vec4 & color, const char * format, ... ) #
Writes the ordinary message to the console and the onscreen overlay.
Arguments
  • const Unigine:: Math::vec4 & color - Four-component vector specifying the text color in the RGBA format.
  • const char * format - Formatted text.
  • ... - Arguments, multiple allowed.
static void message ( const char * format, ... ) #
Arguments
static void warning ( const char * format, ... ) #
Writes the warning message to the console and the onscreen overlay.
Arguments
static void error ( const char * format, ... ) #
Writes the error message to the console and the onscreen overlay.
Arguments
static void messageLine ( const Unigine:: Math::vec4 & color, const char * format, ... ) #
Writes the ordinary message to the console and the onscreen overlay followed by the line terminator.
Arguments
static void messageLine ( const char * format, ... ) #
Arguments
static void warningLine ( const char * format, ... ) #
Writes the warning message to the console and the onscreen overlay followed by the line terminator.
Arguments
static void errorLine ( const char * format, ... ) #
Writes the error message to the console and the onscreen overlay followed by the line terminator.
Arguments
static void onscreenMessage ( const Unigine:: Math::vec4 & color, const char * format, ... ) #
Writes the ordinary message to the onscreen overlay only.
Arguments
static void onscreenMessage ( const char * format, ... ) #
Arguments
static void onscreenWarning ( const char * format, ... ) #
Writes the warning message to the onscreen overlay only.
Arguments
static void onscreenError ( const char * format, ... ) #
Writes the error message to the onscreen overlay only.
Arguments
static void onscreenMessageLine ( const Unigine:: Math::vec4 & color, const char * format, ... ) #
Writes the ordinary message only to the onscreen overlay followed by the line terminator.
Arguments
static void onscreenMessageLine ( const char * format, ... ) #
Arguments
static void onscreenWarningLine ( const char * format, ... ) #
Writes the warning message only to the onscreen overlay followed by the line terminator.
Arguments
static void onscreenErrorLine ( const char * format, ... ) #
Writes the error message only to the onscreen overlay followed by the line terminator.
Arguments
Last update: 26.07.2024
