Configuring Projections
Syncker provides the projection setup mode that allows you to create any setup for your project by adding and adjusting views to be displayed by the master and slaves. For each view you can use a display or projector. After creating views you can set up required image warping and edge blending parameters for each of them. All changes will be transferred over the network and applied automatically.
To enable the setup mode, run the syncker_setup console command from the master or a slave as follows:
Source code
syncker_setup 1
The setup mode can also be enabled via the System Menu:
  1. Open the System Menu by pressing Esc.
  2. Go to the Plugins tab and enable the Show projections configuration option in the Syncker group:
The setup mode will become available:
Configuration Setup Mode
To navigate the scene, use the way like that of the Editor 2 Scene navigation.
If a display or projector is selected, you can focus the camera on it by pressing F key.
The viewer is positioned in the center of the scene and corresponds to the main master camera.
Coordinate system of the configuration is expressed in meters.
To set up a projection configuration, you should perform the following steps:
  1. Add the required number of displays or projectors.
  2. Form the projection setup by adjusting the required parameters of the displays or projectors.
  3. Click Setup Projections and adjust the required projections.
Configuration Requirements#
Screen/projection configuration for Syncker should meet the following requirements:
  • Each display in the configuration should correspond to one of the monitors/projectors.
  • Position and orientation of each display/projector must be relative to the main master camera. The closer the monitor is to the viewer, the higher is the FOV value.
Create Displays and Projectors#
If you are going to use a multi-monitor setup, you need to add the required number of displays or projectors and adjust its transformation and size.
To add a new display, press the Add button on the Objects panel. The default display named display0 will be added. Each display corresponds to one of the monitors/projectors.
New added displays, projectors, and projection screens are automatically assigned a corresponding index added to their name.
It is also possible to generate automatic virtual environment setups.
Wall Setup#
The Wall preset is useful to generate a multi-monitor setup of displays formed as an array.
Choose Add Wall Setup to open the Wall Generator window.
The Wall Generator has the following parameters:
Screen Width, Screen Height Size of each display in setup.
Border Width, Border Height Distance between displays along the axis corresponding to displays' width and height.
Columns Number of columns.
Rows Number of rows.
Name Prefix Name prefix for each display in setup.
Surround Mode Defines whether displays are placed on a flat surface or on a sphere, while being oriented to the viewer.
Position Position offset for the group of displays.
This parameter is available if the Surround Mode is disabled.
Radius Radius of the sphere which the displays should be placed on.
This parameter is available if the Surround Mode is enabled.
Rotation Rotation of the group of displays along all axis.
Click Ok to generate setup.
Flat mode
Surround mode
CAVE Setup#
The CAVE (Cave Automatic Virtual Environment) multi-projector setup generation is supported:
Choose Add Cave Setup to open the Cave Generator window.
The Cave Generator has the following parameters:
Width Width of the whole setup.
Height Height of the whole setup.
Depth Depth of the whole setup.
Mirror Sides Defines whether side displays should be flipped horizontally.
Mirror Up/Down Defines whether up and down displays should be flipped horizontally.
Projection configuration for CAVE
Dome Setup#
The Dome multi-projector setup generation is supported:
The Dome projection is usually built of several layers of projectors from bottom to top. For example, the 5-3-1 setup describes configuration that has 5 projectors on the lowest layer, 3 on the middle one and 1 projector oriented on the ceiling top.
Choose Add Dome Setup to open the Dome Generator window.
The Dome Generator has the following parameters:
Projectors aspect ratio The proportional relationship between displays width and height.
Layers The list of layers in setup. Use the Add and Remove buttons to manage the list of layers.
Projectors Number of projectors (displays) in the selected layer.
Projection configuration for Dome
Import Mesh#
Also, configurations from the previous versions of the Syncker Plugin are supported. To import configuration in the *.mesh format, choose Import Mesh on the Objects panel and then select the desired file in the Load Mesh Configuration dialog.
Configuring Displays and Projectors#
Selecting and Positioning Displays
To select a single display, choose on the toolbar or by pressing Q on the keyboard and perform left mouse click on the display. You can also select a display by using the Objects panel.
The Ctrl key can be used for multi-selecting displays either in the list or in the view window. The Shiftkey can be used for immediate selection of more than two items in the list.
Configuring and Transforming multiple selected displays is also possible.
Use the transform tools to manually transform a display or several displays the same way as in the Editor 2.
Use the pivot tool to choose between the pivot modes: World or Local, so you can transform displays just the same way as in the Editor 2.
Display Parameters
To configure the selected display, adjust parameters on the Parameters panel:
Name Name of the display.
Enabled Toggles the display on (1) and off (0). If the display is disabled, the corresponding sign appears near its name in the Displays list. By default, displays are enabled (set to 1).
Pos X Position of the display along the X axis relative to the viewer.
  • If a positive value is specified, the display is moved to the right relative to the viewer.
  • If a negative value is specified, the display is moved to the left.
Pos Y Position of the display along the Y axis relative to the viewer.
  • If a positive value is specified, the display is moved forward relative to the viewer.
  • If a negative value is specified, the display is moved backward.
Pos Z Position of the display along the Z axis relative to the viewer.
  • If a positive value is specified, the display is moved up relative to the viewer.
  • If a negative value is specified, the display is moved down.
Rot X Rotation of the display about the X axis.
Rot Y Rotation of the display about the Y axis.
Rot Z Rotation of the display about the Z axis.
Width Width of the display.
Height Height of the display.
Positioning and Configuring Projectors#
Projectors are created by using the Add button in the Projectors window.
To manipulate a projector, select it from the Projectors list and move the required manipulator in the viewpoint.
It is not recommended to change the projector's location, unless you need to create a projection from another place.
In addition to the parameters available for displays, projectors have the following parameters:
Aspect ratio atio of the width to the height of the projected image.
VFOV Vertical FOV of the projector.
Horiz. offset Horizontal offset of the projector's viewport.
Vert. offset Vertical offset of the projector's viewport.
Display Parameters
Any changes in these parameters are immediately applied to the selected display/projector.
To delete a display, press the Remove button or Delete key.
Setting Up Projections#
A projection for the display or projector is adjusted via the Projection Configurator window that is opened by pressing the Setup Projections button on the Objects panel:
  • Any changes made via this interface are immediately applied to the specified projection.
  • For displays, the projection is set up relative to the viewer's position (as it is fixed).
Use the following buttons in the Projection group on the Parameters panel to:
  • Copy the projection configuration of the selected display.
  • Paste the projection configuration to the selected display(-s).
  • Setup the projection configuration of the selected display.
A projection can be saved to the .proj file: each file stores a single projection. All projections used in the configuration are saved to the .sync file.
Calibration#
The Calibration Pattern button on the Objects panel displays the Calibration Grid Setup. Using this setup, you can enable and configure the grid pattern to fit your projection shape or fill in the projection with a certain color for fine-tuning the displayed image and avoiding its distortion.
The following groups of calibration-related options are available:
Main Control the general view of the calibration pattern.
  • Visible — if enabled, displays the calibration pattern on the projection.
  • Distance — distance from the camera to the grid. The difference is noticeable with the Box type of projection.
  • Type — type of the calibration pattern.
    • Sphere. Enables the Sphere Cut option that allows hiding the top and bottom poles of the sphere.
    • Box
    • Color — colors the projection into the selected color.
Lines Define the distance between the lines and the number of minor (auxiliary) lines.
  • Vertical Step — the distance between major horizontal lines.
  • Horizontal Step — the distance between major vertical lines.
  • Minor Count — the number of secondary lines between the two neighboring major lines. Is set individually for vertical and horizontal lines.
Text Toggle on and off the text on the calibration grid and define its size.
Line Highlight Enable highlighting of one horizontal and one vertical line. The lines are invisible, when their indices are set to zero.
If Keyboard Control is enabled, you can move the vertical highlight using J and L, and the horizontal — using I and K.
Transform Transform the grid along the vertical, transverse, and longitudinal axes. Only the grid is transformed, the projected image is not transformed.
Color Select colors for corresponding elements of the grid.
Saving and Loading Configurations#
After the screen/projection configuration is set up, it can be saved into a .cfg file to be loaded at any time:
  • To save the configuration, press the Save button on the Objects panel.
  • To load the configuration for editing, press the Load button on the Objects panel.
Last update: 16.08.2019
